February 19, 2018, 10:27:31 AM *
Author Topic: Rv Awnings? What manufacture are you using? Do like them?  (Read 8376 times)
« Reply #15 on: October 31, 2008, 05:53:07 AM »
I decided for the type of camping I do that I didn't want an awning.  We usually travel long distances nearly non-stop and then stay at one location for four to six days.  I bought one of those 10x20 canopies that has a metal frame and poly tarp for $50 at Pep Boys last Christmas.  We set that up and it works real good.  We don't camp at regular campground and everybody has these so nobody complains about it.
I had a regular awning on my travel trailer and it sucked.  It was always hard to get the locks to release and one time the lock would engage so we used a plastic tie to keep it closed.
jjrbus
MCI5C/N Ft Myers FL
« Reply #16 on: October 31, 2008, 06:22:39 AM »
Sort of a side question here, how do awnings mount? Is there any prep work that should be done from inside before closing in the walls?
 I carefully planned the layout of my awning during construction, the bottoms of my arms are at the build line or inside floor level. I installed 2X6 where the bottom of arms would mount. After doing this some people said they used plate aluminum instead. The top channel is mounted to the drip rail.  This is on a 5C with an 8 inch roof raise which requires the shortest arms A&E makes.
 My A&E awning stayed open for the better part of 5 years and looked great!!  Until I parked under an evil tree in FL which quickly trashed it. Then the next tree dropped a branch which put a hole in it!!!! Unless there is a hurricane coming my awning is always open.
 The Zip Dee arms can be heated and bent to fit the contour of the coach if necessary.   HTH Jim
makemineatwostroke
« Reply #17 on: October 31, 2008, 07:01:19 AM »
Depends on what type awning you are wanting lateral arm automatic are nice ,I have Girard on mine the problem with the automatic I don't know about the A&E but Girard and Zipdee need a 120v supply to work properly and will not stand a great amount of wind.Grant is right about parts being expensive for the auto type.I have seen lots of damage to the auto type in Vegas where the wind comes up to fast for the awning to close.Mine was ripped off because I turned the power off and went to eat what turned out to be a $2700.00 lunch.
Every Blue Bird I have owned over the years has had Zipdee from the factory with curved arms, for manual type awning they cost more but for easy operation they are #1 in my book and you install what people call the head knocker rails you don't have any arms in your way to swing and tie down for a manual type Zipdee is the way to go plus they do not rattle when under way and if locked will not unroll like some you see on the road side in a high wind area    have a great day
« Last Edit: October 31, 2008, 07:32:28 AM by makemineatwostroke » Logged
NCRealAuctions
Auctioneer
1975 MC8
« Reply #18 on: October 31, 2008, 06:10:53 PM »
I have a 1975 MC8.  I want a motorized awnig.  I live in Raleigh, NC.  Where can I go that can sell and install on a MC8?  Approximately how much would a awning cost installed?  I really need some guidance.  A local RV store is tryinf to charge me $4200 for a 21' awning plus installation costs.  They said they would have to bend aluminum plate to mount to the curve in the roof of the MC8.   Help please!
makemineatwostroke
« Reply #19 on: October 31, 2008, 06:19:21 PM »
IF the $4200 is for a Girard or Zipdee lateral arm awning that is about the right price I don't know what a A&E will cost, if it is for a motorized with the arms on the side it's that's to much cash   have a great day
« Last Edit: October 31, 2008, 06:20:56 PM by makemineatwostroke » Logged
NewbeeMC9
NewbeeMC9
1981 MC9 8V71, HT 740
« Reply #20 on: November 01, 2008, 06:26:02 AM »
I've only had one awning and it came with my bus, so i'll pass along my 2 sints Wink
Mine is manual, top clip mounted to drip rail,
lower brackets outside the bay doors
        can disconnect to use in "carport mode" and stake legs to ground.
        i like to sit outside in the rain, learned about leaning it the
hardway and filled up the awning and stretched it, now it gets water inside and turns black
       i like not hitting my head on the raill when attached to bus
If i was doing it now:
- figure out a way to get it over the door
- get the cover, or the material right at the bus that is always exposed to the elements to be made of metal/alluminum.
find Oddeseys web page and check out his awnings and streamlined end caps, mounted on top of bus and no side arms
if you splurge on automatic, the mrs. can put it up(sheel feel more independent Wink)
Ross had a pretty good set up too, powered, no down legs to hit head on, mounts to side of bus.
good luck and let us know how it turns out
« Last Edit: November 23, 2008, 09:47:11 AM by NewbeeMC9 » Logged
« Reply #21 on: November 01, 2008, 06:54:33 AM »
The A&E is also 120v but, has more coated cables the Girard or ZipDee. 4 per arm to be exact. And a solid state wind and rain sensor.
« Last Edit: November 01, 2008, 06:57:32 AM by Nick Badame Refrig. Co. » Logged
« Reply #22 on: November 01, 2008, 10:32:49 AM »
I had an awning on my first motorhome and would set it out each time we camped.  It was sometimes useful and sometimes a nuisance due to wind.  I once hit a leaning telephone pole with it while parking, and also had to be careful that it would drain properly in a sudden storm.  I would retract it if we were going away for more than an hour or so if I thought that the weather might change.  I never got around to installing one on the last bus and did not seem to miss it.  We do not have one on this bus yet either, have not really camped all that much, but have not missed it yet.  I may get a nice beach umbrella.  Come to think of it, the thing I really did like about the awning on the motorhome was that it protected the doorway from the rain.  However, even if I install one, it will not do that on the bus.
« Reply #23 on: November 01, 2008, 08:50:23 PM »
Lin,
I also got one of those canopies like Belfert described. I haven't used it yet but it is there in the baggage comp if I need it. Quick and cheap.
I don't think it is tall enough to cover the bus door but some extensions could probably be fabricated from tubing without too much work.
Melbo
MC8 under construction
« Reply #24 on: November 22, 2008, 05:39:43 PM »
Has anyone had any experience with this awning??
http://www.rvawningsonline.com/index.php?main_page=product_info&products_id=135&zenid=vna1ajknm0sb1kvmtt76lm4s16
I was just wondering I kind of liked the arms not being in the way.
Melbo
jmblake
Jason & Martha Blake
« Reply #25 on: November 22, 2008, 07:42:39 PM »
Melbo
 We have the carefree in the travler series 21' with the steep pitch arms, the eclipse wasn't available with steep pitch arms, the steep pitch makes the arms shorter so they don't come down the side of the coach as far and the rain does'nt puddle on the awning. This was our first year with it and we love it so far and no trouble's. Jason
« Reply #26 on: November 22, 2008, 07:59:12 PM »
I don't believe those have a wind or rain sensor would not be a good awning for a windy or rainy climates,holding the switch to close or open you may be short on time.  have a great evening
jmblake
« Reply #27 on: November 22, 2008, 08:11:55 PM »
 I talked to several other people that had the rain & wind sensors and they didn't like them, they said the awnings were going in and out all the time with just a little wind change, so they don't use the sensors and the one man said he was on his 3rd sensor and very expensive to replace. we never had any problems if you are not sure of the weather put in at nite or before you go away. better safe then sorry plus you can stay inside and just push a button in or out. Jason
makemineatwostroke
« Reply #28 on: November 23, 2008, 06:35:21 AM »
Jason;any of the electric or automatic awnings are going to give you trouble sooner or later.I have Girard on my bus and they are a problem now and then if i didn't have the Girard on my bus and installing  new awnings I would buy the Zip Dee manuals with the rail slide where the arms are out of the way.I do like the idea that your awning is operated by 12 v and not 110 v like most of the automatic or electric. have a great day
kingfa39
« Reply #29 on: November 23, 2008, 09:21:35 AM »
I have a A&E on my 06, one man operation, love it
Frank Allen
