May 23, 2018, 07:37:11 PM *
Pages: 1 2 [3] 4   Go Down
Author Topic: iminaccess's last post re: veg oil conversion  (Read 10590 times)
Fred Mc
« Reply #30 on: November 01, 2008, 10:40:18 PM »
I was wondering how long you can store wvo once it is cleaned/dewatered etc.
I only use my bus in the summer so I was thinking of collecting the oil during the winter for use in the summer.
Fred Mc.
jackhartjr
« Reply #31 on: November 02, 2008, 07:32:10 AM »
Folks, this is by far the best discussion on ACTUAL use of WVO in buses I have seen!
Jack
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
tiredofjerks
« Reply #32 on: November 02, 2008, 08:23:47 AM »
Fred Mc.
If you properly filter and dewater your oil and store it in plastic, stainless steel or aluminum containers with as little air space as possible you can store it for a very long time.
tiredofjerks
« Reply #33 on: November 02, 2008, 08:31:34 AM »
Tired,
Can you expand a little on the cent filter you use on the road?  Type, brand, cost "G" force....any info.
Thank you,
I'm using a spinner II centrifuge with 60 GPH rating. I have 2 different pump motor combinations. I can pump oil onto my bus, off of my bus and from any onboard tank to tank I want to.
Fred Mc
« Reply #34 on: November 02, 2008, 09:31:17 AM »
It seems to me that I read that someone was using a power steering pump as a centrafuge.
Anyone have any comments on that.
Fred M
tiredofjerks
« Reply #35 on: November 02, 2008, 09:39:36 AM »
Fred M
They are used to "Power" the centrifuge with oil pressure. Not as a centrifuge.
ilyafish
« Reply #36 on: November 02, 2008, 09:58:25 AM »
tiredofjerks,
do you have any pictures available of your setup? i am very interested in learning more.
also, is it worth carrying over 800 gallons on board? how much weight is that approximately?
Own: 1981 MCI MC9 w/
Veggie Oil Conversion
Live:  Flemington, NJ
1 Corinthians 9:19-22
Chaz
4108, 8V71 w/auto .
« Reply #37 on: November 02, 2008, 10:12:09 AM »
Peach,
  I built a centrifuge for filtering VO and then lost the access I "thought" I had all sewn up for getting it. (a supposed friend that said I could get all I could handle)
  So if you would be interested in a 55 gallon barrel centrifuge.........  Wink  See it here:  http://s58.photobucket.com/albums/g279/Skulptor/Centrifuge/
  Good luck with it!! I'm extremely envious.
   Chaz
tiredofjerks
« Reply #38 on: November 02, 2008, 10:47:56 AM »
tiredofjerk
I drove 1,600 miles without having to stop for fuel. And if I had a co-driver I wouldn't have to stop at all.
Veg oil is 7lbs a gallon.
ilyafish
« Reply #39 on: November 02, 2008, 11:14:44 AM »
so your getting 2 miles to the gallon?
my current capacity is about 195 gallons and i can go about 1000 miles with all my tanks filled.
tiredofjerks
« Reply #40 on: November 02, 2008, 11:45:52 AM »
Where did you come up with that? I drove 1600 miles without getting fuel but I only used about 300 gallons. That's how things get all screwed up on this forum.
« Reply #41 on: November 02, 2008, 12:22:53 PM »
Guys,
Google "Simple Centrifuge" to see an alternative to the "Spinner" that Tired and many others are using.  My reason is that 3400 rpm on an 8 inch wheel makes spooky G forces.  Spinner works, though.
2 cents,
ilyafish
« Reply #42 on: November 02, 2008, 12:35:24 PM »
My apologies....I thought you meant 1600 miles until you were out of fuel
« Reply #43 on: November 02, 2008, 03:55:02 PM »
Quote from: Ednj
tiredofjerks
"Good to see you posting"
Ed I too am glad to see him posting again!
And I'm glad to see that this post thread is actually being civil and informative! FWIW Grin  BK  Grin
« Last Edit: November 02, 2008, 04:21:52 PM by Busted Knuckle » Logged
tiredofjerks
« Reply #44 on: November 02, 2008, 04:19:28 PM »
Quote from: Ednj
tiredofjerks
And I'm glad to see that this post is actually being civil and informative! FWIW Grin  BK  Grin
HuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuhHuh
Pages: 1 2 [3] 4   Go Up
