February 23, 2018, 08:37:18 PM *
Author Topic: Need help with bus  (Read 2138 times)
heintzbus
« on: June 22, 2006, 02:05:51 PM »
       I cannot find the Voltage Regulator on my1981 MCI9. I see F1 going to rear junction box terminal 48 and 49 then going to front of bus. Is mine missing or is it in a front compartment?
Beatenbo
1993 MCI 102 C3 Cat Power
« Reply #1 on: June 22, 2006, 06:02:01 PM »
I have owned 5 MCIs and every one I had including my 1980 MC-9 was in the back baggage bin right side on bulkhead. Unless a previous owner hid somewhere. Check rear engine compartment left rear and see if moved close to that junction box. Good luck. Charlie B.
« Reply #2 on: June 22, 2006, 06:05:21 PM »
I've always found them in the right rear bay also! BK
 Grin
mak
Southern California location
« Reply #3 on: June 22, 2006, 07:14:20 PM »
Yes, MCI  9 bus regualtor in last bay blukhead wall passenger side behing a metal protective box. If your just setting the volage, you can do so without re-moving the box, just place a very small sloted screwdriver in the hole and turn a little. If the regulatory is not working. you can just replace the circut board for around $75 and 4 screws. easy to do.
I may have started it, but you'll have to finish it!
Located in So CA (Orange County)
