April 22, 2018, 07:10:32 PM *
Author Topic: Drive tires  (Read 6953 times)
« on: November 18, 2008, 07:36:42 PM »
We are going to replace our drive tires. What are people's top choices? One guy has recommended Goodyear as the best buy all around.
Thoughts?
God bless,
PP
Will & Wife
« Reply #1 on: November 18, 2008, 07:45:42 PM »
I have a Love/Hate relationship with Michelin. I love the ride and they wear super. However, I've had to replace them in the past due to weather checking. They got so bad you could see the wire bands and the cracks were at least 1/2" deep. The tire shop guy took out a pen knife and inserted it into one of the cracks and then just shook his head. The inside drives that never saw the light of day still looked like new tires. I do keep my tires covered when we're parked, BTW  Wink
On another thread, someone stated they purchased 6 new tires for $1900. Still waiting to hear what brand he got  Shocked for that price and how he likes them. Good luck, Will
« Reply #2 on: November 18, 2008, 07:49:58 PM »
I installed six TOYO M122 tires on my 4104, mostly because the price was right and they are the most popular truck tire around these parts. I figure if I need one on the road I'll be able to find one.
They are also all-position tires so I can rotate them.
« Reply #3 on: November 18, 2008, 08:11:55 PM »
I run Toyo M 111 Z 12R22.5 on my Eagle for the soft ride but I think any major tire manufacture would be ok they all make different compounds for their tires just buy the one that is best for the price and the ride
« Reply #4 on: November 18, 2008, 08:39:21 PM »
Gotta give VERY serious consideration to re-manufactured tires for the drives.
If you go Goodyear, Michelin or Bandag re-caps, you have the 1-800 number, continent wide support, and a warranty.
Thousands of fleets can't be wrong?
I still say find someone running a truck or bus and buy what he/she would buy from you in three-four years for $100 discount per tire. You get fresh ones every time for $100 a tire, he/she runs the rest of the tread off them and everyone is happy? Right down to swapping rims as well.
Southern truckers will run all position tires, eight make the drives,  northern 5 tons will need an axle's worth of 4 lugged drives...you get the picture...
Save someone a few bucks, save yourself some bucks, everyone wins?
« Reply #5 on: November 18, 2008, 10:09:21 PM »
As stated on another thread, since buses are relatively low powered with high gearing, it would be hard to spin out the tires unless you're in mud or sand, etc.  I run the same tires all around (Michelin XZE 16 ply).  This allows you to rotate the tires as they wear.  If you run your tires first on the drives for the first 20,000 miles or so, they will drive straight and true if you rotate them to the steers.  But remember, if you do rotate them, use the same side duals to switch to the front.  The best is to use the left side duals to switch with the front since they wear a bit slower.  Good Luck, TomC
scanzel
« Reply #6 on: November 19, 2008, 03:53:22 AM »
I have new Michelin XZE on the fronts, when I bought the bus they were already on it. The rear 6 are Firestone radials. They were $1900 new, mounted and balanced because my father is a Firestone retiree and gets a good discount so this is why only $1900.
Steve Canzellarini
Berlin, CT
1989 Prevost XL
busshawg
« Reply #7 on: November 19, 2008, 08:13:00 AM »
I find that tires seem to be a very personal preferance. Myself I'm with busswarrior on buying used virgin tires from a trucker, Unless your putting 100,000 miles on or more every year.  I like to run a steer tire all the way around. If you get any cupping in the steering you can simply swap it out with a drive.  Unless your trying to get out of a bad parking area the steer tires have done well for me in the past running down the road in all kinds of weather. Michelin is my brand of choice. I will never run a cap tire, just not worth it in my opinion
Have fun
Have Fun!!
Grant
Hartley
« Reply #8 on: November 19, 2008, 09:32:38 AM »
I installed Goodyear G670RV 315/80-R22.5 on my bus mainly due to it sitting a lot and after seeing other tires degrade from sitting I figured I would only be able to put GOOD tires on maybe once this lifetime. 7 Year Warranty and made to sit and not age out from weather. Pretty good traction and ride on the road too..
There are others that are good also but most expect to be driven hard to keep the chemicals flowing and revent rotting and cracking.
Dave...
« Reply #9 on: November 19, 2008, 07:09:24 PM »
OK TomC, you got me there. Why do left rear duals wear less?? Does this also apply to buses?
I drove an 18 wheeler for a few years and never knew that - of course there were a lot of things I didn't know then and still don't!!
Do trucks make more left hand turns than right?
I also cross rotate, it all depends on the condition of the tires I'm rotating.
I do always put the best tire on the outside dual because, as I understand it, they wear faster than the inside but that makes sense to me.  They scrub when turning since they are on the outside of the circle and travel a longer distance than the inside.
« Reply #10 on: November 19, 2008, 07:16:14 PM »
Thanks for all of the info. I like Michelin's also, but my problem is the $$$$ (sound familiar  Grin Grin Grin). We might just have to bite the bullet and go with them, but then again Dave's Goodyears sound good. We will look into different options.
Gus, I'm not sure what the reason is behind it, but our right drive have worn faster than the left side.
Thanks again. This info is very helpful.
God bless,
« Reply #11 on: November 20, 2008, 12:15:34 AM »
Because of the crown of the road leaning the bus to the right, the left tires will wear slightly less then the right.  Also, a normal differential with no traction control will also favor the right side also making the right tires wear slightly faster.  Good Luck, TomC
« Reply #12 on: November 21, 2008, 07:40:00 AM »
Hello.
One of the things I was told: Right turns are typically tighter than left turns where we drive on the right and the inside tires get a good grinding. I expect that we should see the left rear tires showing a slight wear increase for those who drive on the left side?
Which side is the "peg leg" in a bus with a rear mounted engine?
"T" drive different from "V" drive?
Curious minds...
BJ
« Reply #13 on: November 22, 2008, 04:22:58 PM »
As much as our motorcoaches sit new tires are a waste.  I go to Mileage master and buy really good used tirres that they guarantee for around $125.00@  For a motorcoach they are fine.....Steering tires are new naturally..
sivrtnge2
1994 EAGLE 10/45 CAULDWELL CONVERSION
« Reply #14 on: November 22, 2008, 08:04:30 PM »
Hey John,
What ever you decide, I may be able to help you on the price if you like... let me know.
BILL
