January 21, 2018, 03:00:13 AM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Newbee 4106  (Read 9161 times)
Madmike
« Reply #30 on: June 19, 2009, 08:53:52 AM »
Cody,
He told me he was going to set somthing up over the next couple of days. That was yesterday, so I would expect him to e-mail you before the middle of next week. Again I want to thank you for taking the time to check her out. He told me he started her up on Monday and she fired right up, He explains he starts it and lets it run for a little while once a month during the time he is up there aprox 6-7 months. I know he has moved it but I dought it has gone down the road.
You can have this bus when you pry her from my cold dead fingers.
Madmike
« Reply #31 on: July 06, 2009, 04:24:00 PM »
My Father inlaw has sent me the paper work he has on the bus. I don't know what it all means but I could not find a build sheet. I have the Maintenance Manual, Parts Manual, and Service manual. on the front page it is New Engine written in ink 8VA-333-782 also 7087-4020 and last it reads Tag 8v710116. Does any one have a clue what this means? There are lots of notes written in the book and service contact numbers but so far that is all I have.
« Reply #32 on: July 07, 2009, 04:03:46 AM »
8VA-333-782 & 7087-4020 are the numbers on the engine block. The first number is the engine serial number and the second number is the engine configuration. Not sure about the tag number, but it might be the number from the rebuild tag.  Jack
RichardEntrekin
« Reply #33 on: July 07, 2009, 09:10:57 AM »
The origninal poster made a comment about putting fuel additives in the tank, just because the fuel was old.
Don't do it. I know of a number of cases where this has done more harm than good.
No fuel additive will fix the fuel if it won't burn. The problem is that the most common fuel additive is methanol or some other alcohol. The alcohols are used because they are polar organic solvents, meaning they will absorb water and dissolve into organics (diesel). The problem is that the solubility of methanol in diesel is around 1%, so if you dump a bunch of methanol in there thinking you will dissolve the water, all you do is essentially dump a bunch of methanol into the tank which will settle out, and act like water in the fuel filter. The fuel filter should not pass un dissolved methanol. This is not myth, I have a degree in Chemical Engineering.
Run a wooden stick in the filler and pull it out to see if you have algae on the surface before adding an algaecide.
Drain a quart or two out of the tank from the bottom tap. Let it settle and see if you have water. If not fire it up and rock and roll. If you do get water, keep draining and settling a gallon or so at the time until water doesn't settle out any more.
So, if the bus will run on the fuel in the tank, let the filters do their job and trap the crud. If it won't run with the fuel in the tank (which I doubt) then drain the tank and refill.
As you drive and top off with new fuel, you are likely to stir up and redissolve sludge from the bottom of the tank. Again, that's what the fuel filters are for.
Richard Entrekin
99 Newell, Detroit S 60
Subaru Outback toad
Inverness, Fl
Madmike
« Reply #34 on: April 07, 2010, 09:58:55 AM »
What would be a fair price for a Clutch?
Pages: 1 2 [3]  All   Go Up
