February 19, 2018, 04:08:55 PM *
Author Topic: Allison HT746 Temp Sender  (Read 1608 times)
homermandy
« on: June 26, 2006, 05:29:09 AM »
I have an HT746 and I am trying to locate a new temp sender. Previous owners must have removed the sender because I traced a dangling wire near the trans to the guage up front. Question is : Is the correct port to install the sender on the lower right(laying under trans facing engine)? I have what looks like a 1/4" NPT bolt there. It is standard Eagle VDO guages in front. Thanks
1991 Eagle 15
Sammy
« Reply #1 on: June 28, 2006, 01:48:39 PM »
Temp sensor for ATEC is part of internal valve body harness.
Temp sensor for dash guage is usually tapped into a trans cooler port.
Sammy  Cool
