April 24, 2018, 04:19:14 PM *
Author Topic: i discovered a 120v plug in my engine....someone said its used to preheat it?  (Read 7465 times)
ilyafish
« on: January 09, 2009, 09:26:27 PM »
hey guys,
so today i found a 120v plug in the engine compartment coming out somewhere by the engine (it was dark outside) and its about dead smack in the middle of the engine about neck level or so.  not sure if this is stock or if someone put it on afterwards, but i was told by the previous owner when i talked to him that it is to preheat the engine....is this true/is this stock/if not what is it?
thanks guys!
Own: 1981 MCI MC9 w/
Veggie Oil Conversion
Live:  Flemington, NJ
1 Corinthians 9:19-22
plyonsMC9
Big Wheels Turnin'
« Reply #1 on: January 09, 2009, 09:39:11 PM »
We have an '83 MC9 with the 120 volt plug.  A 120v outlet is available at the rear of the bus to plug in an a/c power supply.  I believe this was used at the bus stations to pre-heat the engine.  You can probably trace the wire to a "plug" where it enters the engine block. This should be the heating element.
In our case, this no longer works - and I'm hoping it is a simple repair.  I've heard these are great for cold weather.  If you live in the cold weather (like we do) you know how hard it can be to start these engines when the temps are waaaaaaaay  below freezing.
Kind Regards, Phil
Northern Arizona / 1983 - MC9
ilyafish
« Reply #2 on: January 09, 2009, 10:02:28 PM »
yup....experienced that today  Roll Eyes
now is there any method of testing if mine still works or not?  also, what amount of time from when plugged in to where its warmed up am i looking at?
jackhartjr
« Reply #3 on: January 09, 2009, 10:13:27 PM »
Don't be like a friend of mine that plugged his up and looked at the meter on the side of the house, the bearings were about to smoke! Grin
If it is a block heater as most folks call them, they will burn a lot of electricity.
Jack
Jack Hart, CDS
8V71 Detroit
4 speed Spicer Trannsmission
TomCat
It's 4:20 somewhere...
« Reply #4 on: January 10, 2009, 12:14:10 AM »
You're very lucky, you have a hybrid coach!
They are very rare!
Plug it in for a few hours and you should be able to tool around town on a single charge!
I'll bet it's so quiet it's freaky!
 Tongue
Jay
87 SaftLiner
Jerry32
« Reply #5 on: January 10, 2009, 01:41:33 AM »
Block heaters work great as there was one on mine and I used it in freezing weather to keep the engine warm. draws about the same as an elextric heater.Jerry
1988 MCI 102A3 8V92TA 740
« Reply #6 on: January 10, 2009, 03:33:59 AM »
To tell if its working, plug it in.  You can often hear them start to "sing" shortly after they are plugged in.  If not, put your hand on the block close to the plug and it should start to feel warm.  Its going to be a 1000 or 1200 watt element - a watt is a watt so about the same as a cube heater.
Utahclaimjumper
« Reply #7 on: January 10, 2009, 03:49:31 AM »
It is ten degrees here and I am running mine now to preheat the engine for a trip in the morning, they preheat the water in the engine and cooling system and are very effective. I installed mine years ago for Utah weather, I have also used my generator in the boonies for the preheat.
They are generally installed in one head of the engine, are not expensive, and available at NAPA stores.>>>Dan
Utclmjmpr
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #8 on: January 10, 2009, 04:44:12 AM »
if the engine is a V71 series most on the right head, on 82 series it will be on the right lower corner of the block looking from the front of the engine on both      good luck
cody
« Reply #9 on: January 10, 2009, 06:09:58 AM »
For anyone that lives in the colder areas of the country, that plug certainly comes in handy, just by plugging it in for an hour or so makes it easier to start without taking down your batteries or damaging your starter, picture filling your crank case with mollases and then putting the engine block in a deep freeze for a while then use a hand crank to turn it over, much easier to warm it up first and less wear and tear on the engine, the meter cost is minimal unless you choose to leave it plugged in all the time in the winter.
VanTare
« Reply #10 on: January 10, 2009, 06:29:31 AM »
I have a fork lift with a Detroit Diesel in it and it has glow plugs for cold weather starting.
David
« Reply #11 on: January 10, 2009, 07:11:33 AM »
At least you have a 120v plug in the engine bay! Tha's on my list of things to do! Wink Now where'd I put that list?  Roll Eyes
« Reply #12 on: January 10, 2009, 07:33:11 AM »
With my memory, I would also include a timer switch.
« Reply #13 on: January 10, 2009, 12:38:05 PM »
Ditto! Wink
« Reply #14 on: January 10, 2009, 12:44:33 PM »
We have a similar plug. And ours works Grin Cheesy Grin!!! It does a fine job of heating the engine, if we have been plugged in for a while.
God bless,
