May 27, 2018, 02:55:25 PM *
Author Topic: i discovered a 120v plug in my engine....someone said its used to preheat it?  (Read 7651 times)
superpickle
« Reply #15 on: January 10, 2009, 01:04:37 PM »
Im moveing to Montana, i will need Block Heaters for my Vovlo, Kia, Wife, 4 dogs and me.. Huh i dont thimk im going to like this  Undecided
Support Global Warming:
Drive an SUV.
cody
« Reply #16 on: January 10, 2009, 02:31:11 PM »
I got used to it after a while but my dog really hasn't adjusted to the block heater yet.
« Reply #17 on: January 10, 2009, 04:22:53 PM »
Just really check that cord to the block heater out very good. I once lost a building and contents plus the vehicle that was plugged into a block heater. In fact here in farm country many fires seem to occur due to block heaters starting fires. The cord on my 8v71 was pretty bad so I cut it off and if need be will replace the whole unit if I ever do any winter excursions. Later
« Reply #18 on: January 10, 2009, 08:39:43 PM »
Yes, check the length of the electric cord for cracked insulation and all the usual electrical wire safety stuff. No broken ground pins...
Think what might happen if the cord is chafed through against the coach body, and the ground pin is snapped off the plug....
Replacement cords may be readily purchased, in many lengths, that will just plug in to the heater.
Block heaters are a lovely thing and another option available for warming the engine to prepare it for starting, providing a load for your generator, bragging rights at a bus rally, and on and on...
plug it in for as long as it takes to get the block warm, and no more, to save electricity.
Oregonconversion
« Reply #19 on: December 07, 2011, 09:32:31 AM »
Should I use my block heater at night when it gets down to 28F or so? I am talking about when the bus is just parked for storage.
1977 MC8
8V92 HT740
« Reply #20 on: December 07, 2011, 09:36:04 AM »
No not just for storage, just if your gonna be starting it.
Jerry32
« Reply #21 on: December 08, 2011, 06:15:30 AM »
Helps keep the bedroom warm too! I put a switch in the bedroom to turn it on so I xan start warming the engine without going outside.
1988 MCI 102A3 8V92TA 740
zimtok
« Reply #22 on: December 08, 2011, 06:16:09 AM »
I have noticed that below 60deg I can tell a difference in the bus starting.
I have my block heater connected to my shore power/generator for the winter.
If I'm going to be connected to shore or have the generator running for long periods I disconnect the block heater.
I just plug in my shore power about 2 hours before I have to leave for a gig and the block is warmed and also the interior of the bus because of the space heater I have plugged in.
I also start the generator about an hour before leaving the gig to warm up the bus and engine.
1960 PD4104-4971 - Memphis TN
http://www.eddielsmith.com
« Reply #23 on: December 08, 2011, 06:38:19 AM »
On my big rig, I had an Onan 6.5 Emerald Commercial gasoline generator (the compact Diesel gensets weren't made yet).  Whenever the generator was running, the block heater was also-no matter the temperature outside.  It created a constant 1500 watt load that kept it from carboning up.  Hence in the 12,000 hours that it lived, never had to have the cylinder heads off for de-carboning.  Onan didn't believe me on that one-that no carboning and the unit lasted 12,000 hours.  Amazing what good maintenance will do.  Good Luck, TomC
Mex-Busnut
« Reply #24 on: December 08, 2011, 06:39:06 AM »
I don't see one on my engine. Would somebody with a 6V92TA be kind enough to tunnel out to your bus through the 10 feet of snow and post a picture of this?
How expensive is it to purchase? How difficult to install?
Thanks in advance!
Jake brakes
Scott & Heather
MCI-9 & MCI-102
« Reply #25 on: December 08, 2011, 06:54:52 AM »
Quite the thread resurrection! Ours has a stock block heater. Works wonders. Below 40 and coach not plugged in? No starty. Plugged in for a few hours? Starty.
Scott & Heather
thomasinnv
Derrick Thomas
« Reply #26 on: December 08, 2011, 09:19:01 AM »
Dr. Steve, you might not have one. They were not installed on every engine. Look in the end of the block just under the head for a chord coming out. There were a few different places they put them, but that is the one I know of. (I think the most common too)
1998 MCI 102-DL3
Series 60 11.1/Alison B500
