January 23, 2018, 02:16:53 AM *
Author Topic: What is the GPH fuel flow on an 8v71?  (Read 2735 times)
Barn Owl
Roanoke, VA
PD4106-1063 "Wheezy Bus"
« on: January 10, 2009, 09:58:56 PM »
I have been given a Davco 233 diesel pro filter. It is rated for 60 gph. Is the 8v71 total flow higher than that?  Can I use that filter or do I need the 382? I have found gph use on some marine boards but I need total flow numbers that includes pass throughÖ.right?
oldmansax
« Reply #1 on: January 11, 2009, 05:00:16 AM »
If you get 7MPG @ 60 mph you will burn about 8.5 gals fuel in 1 hour. 5 MPG will burn 12 gal/hr. 3 MPG (what I used to get with my old hot rodded 8V92) will burn 20.
TOM
RTS/Daytona
« Reply #2 on: January 11, 2009, 06:30:08 AM »
The "spill rate" (the amount of fuel returned to the tank)  on a 2 cycle detroit is huge
(it's used to cool the injectors)
a 6V92TA pumps 62.3 GPH at full load
rule of thumb (you burn only about 20% of what is pumped at full load)
Hope that helps
« Reply #3 on: January 11, 2009, 06:45:08 AM »
Also 88.5 GPH with the high volume pump      good luck
Barn Owl
Roanoke, VA
« Reply #4 on: January 11, 2009, 10:33:48 AM »
Crap, I guess I need to look for a 382 which has a 150 gph capacity.
Davco filter link
« Reply #5 on: January 11, 2009, 11:00:11 AM »
Great information.  I would not have thought so much fuel was flowing.
steve5B
« Reply #6 on: January 11, 2009, 11:48:32 AM »
    As Oldmansax mentioned the amount of fuel per Hr. x fuel cost ....... it's rather expensive per HR. to operate.
    I never thought about it in that way.
    Steve 5B......
WWW.WINNERSCHOICECORPORATION.COM
"It's all in the name the name says it all"
oldmansax
« Reply #7 on: January 11, 2009, 04:46:20 PM »
Good info. I wasn't thinking about the returns....
Steve, when I was running that old 8v92, I was paying $0.19 to $0.25 a gallon for fuel.
If I had just put up a million gallon tank & stored fuel............  Grin Grin Grin
TOM
Barn Owl
Roanoke, VA
« Reply #8 on: January 11, 2009, 07:14:03 PM »
How does one identify a high volume pump and what is the gph for the standard pump?
Slow Rider
« Reply #9 on: February 07, 2009, 01:01:10 PM »
Bump
Yes I am a BUSNUT
1976 MCI MC8
