May 21, 2013, 07:47:43 AM *
Author Topic: Which Sikaflex Do You Use  (Read 1026 times)
« on: January 29, 2009, 05:12:35 PM »
I need to get some black Sikaflex.  I have had 291, but in reading descriptions, I came across Sikaflex 291 Lot.  This is said to be almost as strong, a little slower setting, and a little more flexible.  Also 521UV looked interesting.  Any experience with these?
http://www.sikaindustry.com/ind/ipd-ma-products
Slow Rider
« Reply #1 on: February 01, 2009, 04:47:51 PM »
Bump
Yes I am a BUSNUT
1976 MCI MC8
Sojourner
Jesus Love You!
« Reply #2 on: February 01, 2009, 08:38:20 PM »
Lin...It all depend what you want it to do with and what type of material being use in.
Need more detail of the project before we can help you.
Sojourn for Christ, Gerald
« Reply #3 on: February 01, 2009, 08:47:44 PM »
Gerald,
That makes sense, but actually I was hoping that one would be a good compromise as an all purpose product.  There are some areas around windows and such that could use some re-sealing.  I also wanted to use it to re-enforce and fill gaps in some weather stripping around the entry door.  Since these small tasks will not use anything near an entire tube, the thought was to find the one that would be suited to the most RV applications so it will be available for the future.  I have read that 291 is most commonly use by RV repair places, but wondered whether the other two mentioned would be more adaptable.  I am not concerned with any high strength requirements like mounting siding.  Thanks
boogiethecat
« Reply #4 on: February 01, 2009, 10:37:26 PM »
Play with some Sikaflex 1A Construction Sealant, from the building construction industry.  Get it at White-cap  or a construction supply place ...
  Super cheap ($3 per caulking gun sized tube), black
 I use it everywhere on my buses for general purpose all-around, windows, gluing things, roof caulking...basically anywhere... and it works very well.
Cleanup with Naptha and a rag...
1962 Crown
San Diego, Ca
Ray D
« Reply #5 on: February 02, 2009, 06:33:21 AM »
Ditto on the 1-a, but try denatured alchahol for the cleanup, you'll like it.
Ray D
CAROLINABOY
« Reply #6 on: February 02, 2009, 07:39:26 PM »
I used sikaflex 252 on my coach it works very well but is expensive $8.00 a tube online
servant for JESUS CHRIST
coachconverter
« Reply #7 on: February 03, 2009, 01:44:16 PM »
If bonding metal to metal, I use 252, and you'll need the cleaner and primer.  Costs more, but worth it!
