March 19, 2018, 03:24:40 PM *
Author Topic: Inverter wiring  (Read 1063 times)
« on: February 23, 2009, 06:35:01 PM »
Question guys, can I wire an inverter parallel with the 110 volt power pole feed to an item?? or will I get feed back and blow something.  I now have those circuits seperate, an item is either fed by the inverter or power pole but not both. ??>>>Dan
 EX 4106 (presently SOB)
Cedar City, Ut.
 72 VW Baja towed
« Reply #1 on: February 23, 2009, 11:13:29 PM »
Dan, most inverters warn against damage if they are backfed, which is what you are describing. I don't know if the Trace SW will tolerate this.
I think that you should check for the information on your model of inverter.
For what it's worth.
Tom Caffrey
Tom Caffrey PD4106-2576
Ketchikan, Alaska
