May 23, 2018, 11:31:17 PM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Should ceiling fans suck or blow?  (Read 11201 times)
« Reply #30 on: March 04, 2009, 01:22:19 PM »
On my bus it isn't possible to open the windows,
They don't swing out for emergency exit?  Every coach I've seen has the windows hinged at the top and latched at the bottom.
This means that you can put a screen across the inside, open the window and prop it open through a small hole in the screen.
No, European coaches like mine are required by law to have emergency exit doors rather than using the windows to escape. In fact the windows don't even have frames as they are bonded directly to the steel. They are also very large, have curved glass and are double glazed (twin pane), so are incredibly heavy - but I love them, and they are one of the main reasons I bought my bus.
BG6
« Reply #31 on: March 05, 2009, 01:23:05 PM »
Yeah, that would put a crimp in things.
Could you modify an existing window?  You could single-pane it and put a small slider at the bottom.
« Reply #32 on: March 05, 2009, 02:29:58 PM »
Anything is possible, but there is no need to as, thanks to the replies to this thread, I've realised that I just need to use the bus ventilation as it was originally designed. Air in at floor level and out at ceiling level - obvious really. I think some of the later comments regarding awnings are equally valid; I've always planned to have awnings but don't have any fitted yet, and have experienced how hot it can get in the bus with the windows unshaded (contrary to belief, it does occasionally stop raining here, and not only because it's snowing instead). Anyway, it's entirely possible I will take the bus next time I drive down to an event in southern Spain, and then I will wish I had a roof-ful of AC units.
Pages: 1 2 [3]  All   Go Up
