Most Onans including the diesels have a "HOLD-RUN" relay inside the control panel.
It is powered by the A.C. Output of the generator section. They are usually 120 v.a.c
relays.
If that relay gets fried due to someone fiddling with the throttle or an engine surge that causes the voltage controller to fail the relay may need to be replaced. But most are soldered onto the engine control board. ( usually means buying a new board $400 or so. ) Then if the Voltage control board got cooked that is as much or more than the engine board. Those relays don't like 185 volt surges at all.....
Never let anyone fiddle with the throttle linkage or governor linkages even if they tell you that "surging the engine will blow the carbon out !! Yikes "...
Some of the diesels also have a fuel pressure switch that shuts down the electric fuel pump if the "RUN" relay is not locked on. Let off the button and it quits...
I have been around this stuff way too long I fear.....
