May 24, 2013, 04:22:08 PM *
Author Topic: 240 volt shore power wiring size suggestion  (Read 2852 times)
DROdio
WonderlandBus
1989 VanHool T-815 - "WonderlandBus"
« on: April 09, 2006, 12:22:33 PM »
question:
what AWG wire do i need to get for the incoming 240 volt shore power wiring?
I'd like to get a 50 foot length.
also, do any of you have shore power hooked up to accept both 110v and 240v (for when 240v isn't available)?  if so, do you use separate wires for 110, or do you just have an alternate plug configuration & switch?
thanks!
DROdio
"WonderlandBus"
1989 VanHool T-815
Daniel@WonderlandBus.com
www.WonderlandBus.com
« Reply #1 on: April 09, 2006, 04:11:21 PM »
question:
thanks!
DROdio
6AWG is the standard size for a 50 amp shore cord. It should be four conductor with two hots, neutral and ground.
50 feet will be extremely heavy and very hard to work with. 25-30 foot is usually standard I believe.
Unless there is some drastic need for 240 volt appliances in the coach, most are wired for 120 volts only and the two legs of the 240 volts are used for individual 120 volt circuits.
Sorry, I forgot to answer the rest of your question.
This can get very complicated with the use of either 240 or 120 volts shore power, the wiring of the genset and the automatic transfer switch hookup. I would recommend you get help from some one on the board who is thoroughly familiar with this before you start. I believe Dave Galey has a book that covers it. There have been literally hundreds and hundreds of posts over the past few years on the different boards on this subject. I ereally do not feel qualified to desigh a complete system.
PS I forgot the inverter and battery charger also comes into this design.
« Last Edit: April 09, 2006, 04:49:06 PM by DrivingMissLazy » Logged
« Reply #2 on: April 09, 2006, 04:37:22 PM »
Code says 6 gauge for 50 amp. It should be 4 wires Green=ground, white=neutral, black= hot (A phase), and red=hot (B phase). Some pre-made cables will have 1 gauge smaller for the green/ground wire. Per code, this is OK. Standard RV shoreline length is 35'. As richard mentioned, a 50 amp cord is very heavy. Here is "Our way" We installed a 125/250 marine type bulkhead fitting on our bus. We then made up 2 shoreline cords, a 50 amp and a 30 amp. We purchesed 2 125/250 connectors to install on the shoreline cords (these plug into thye bulkhead fitting on the bus). Since the 30 amp cord only has 3 wires (green, white, and black, we installed a jumper from the black to the red inside the cord connector. Unless 50 amp is available, we use the much lighter 30 amp cord. You can also purchase adapters to allow a 50 amp cord to be plugged into a 30 amp outlet. YMMV   Jack
