April 27, 2018, 01:40:18 AM *
Author Topic: Coleman Roof A.C. units leaking inside the bus????  (Read 10363 times)
mc8 tin tent
« Reply #15 on: May 01, 2009, 03:45:43 PM »
Dave
 Sorry that I wasn't very clear on which coil to clean,The evap. coil which blows cold air inside your coach. And yes you do need to carefully remove the foil tape(you will need to replace the tape),I think you will find some screws along the sides,carefully pull the sheet metal back and using a small hand sprayer wash down the coil. Dave also at this point you should be able to see the drain pan(look for a possible crack in styrofoam pan) slowly pour water in and along the front edge of the coil so you don't flood the area below the unit ,this should give you a chance to test and locate a leak.
  Dwayne
Dave Siegel
« Reply #16 on: May 02, 2009, 04:42:54 AM »
Thank you Dwayne, now that makes sense. I just didn't go deep enough into the A/C unit.
I will try that and get back with the results.
Dave
            Pinellas Park, Florida
         www.help-assist-list.com
Airbag
« Reply #17 on: May 02, 2009, 07:53:21 AM »
FWIW I have seen it raining inside 40 million dollar jets from condensation. Sometimes it just happens. I hope you find the cause of your problem.
« Reply #18 on: May 03, 2009, 03:36:32 PM »
Airbag,
It rained on me inside a C-130 over the mid Atlantic.  I was REALLY worried and started tasting the "fluid".  I was hoping for a busted drain from the pilots piss tube but I feared hydraulic fluid or FUEL.  You guessed it.....rain from condensate while descending.
4104GA
« Reply #19 on: May 03, 2009, 08:01:52 PM »
 :)Back in time to my aircraft mtc. days anytime we had water blowing from the outlets in the cabin we changed
the water soaked cloth filters at the air turbin machine outlet. Very common in the southern areas with high
humitidy
Enjoy your ride
