January 19, 2018, 01:45:08 PM *
Author Topic: u joints  (Read 1903 times)
ruthi
« on: April 25, 2009, 01:45:26 PM »
Does anyone have a part number for a 1974 gmc buffalo bus? I was told it is a 1710 series. Is there another number that goes with that. I heard maybe 528 or 6__ ? We are on the road, and have one going bad, called a truck shop and they said they have two of the 1710s, a 6 something number. Can someone please get back to me? Thanks
southeast most of the time.
« Reply #1 on: April 25, 2009, 02:34:53 PM »
You might speak to Luke at US Coach in New Jersey.  You won't find a better source for this type of information.  He might even have them in stock to send.
ruthi
« Reply #2 on: April 25, 2009, 02:37:36 PM »
Thanks Lin, thing is, we are traveling, work out of the bus on the road, so, we need to find a fix asap. We are headed to a TA now, so we will see if it is the right one. We are told that it is the same one in a lot of trucks.
roadrunnertex
« Reply #3 on: April 25, 2009, 04:53:19 PM »
"U" joint kit for the GMC 4905 is part number 2366108 a later GMC number 695232.
This above part number crosses over to a MCI number 14F-1-23 to a later MCI number
14F-1-23AM.
Kits are not that costly around $25.00 to $30.00 each
Muncie and Mohawk list them if Luke does not have them in stock.
Hope this helps. Grin
roadrunnertex
« Reply #4 on: April 25, 2009, 05:00:54 PM »
Note! Be very careful do not drive the coach very fast or very far with a bad "U"joint or joints when the "U" joints break this will cause the drive shaft to whip around doing a lot of damage to the drive line parts and or the transmission. Cry
Get it repaired ASAP and keep the "U" joints greased. Roll Eyes
Good Luck Folks!  Grin
ruthi
« Reply #5 on: April 25, 2009, 05:29:17 PM »
Thanks yall. We had a guy look at it, and he said it does have some play in it, but not really bad. We are told truck pro has them. There is one in Nashville, so we will be looking there on Monday.
« Reply #6 on: April 25, 2009, 09:31:33 PM »
Call Luke
856-794-3104
He or the staff will tell you what you need, whether you buy it or not.
And if you need something, it'll be in the courier that day.
Great supporters of our hobby.
Melbo
MC8 under construction
« Reply #7 on: April 25, 2009, 09:53:46 PM »
Just a caution
Driving with a bad u joint can take out a diff
so slow and careful
Melbo
« Reply #8 on: April 25, 2009, 10:27:44 PM »
The simplest is to remove the Ujoint and take it with you to match it at the supply house.  Should be a standard truck type Ujoint.  Good Luck, TomC
ruthi
« Reply #9 on: April 27, 2009, 12:28:05 PM »
Thanks to all for your help. We found someone to do the work, and we found it at Truck Enterprise in Nashville, Pro Truck also had it. It was a 1710,4 bolt, pretty standard. We have had some bad luck lately. The same day, the gen went out. Took it to the same shop, and found out the sending unit went out. Fixed us right up tho, no hassles.
