April 26, 2018, 10:37:37 AM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Stuck 2 carrier aircon units on the roof of our bus...pics  (Read 14207 times)
Beatenbo
1993 MCI 102 C3 Cat Power
« Reply #30 on: July 07, 2006, 10:32:44 AM »
I will drop the subject, but you missed the whole ? I am much aware of the hook up. I am on my 10th bus and have built 2 houses I'm not trying to be creative or use a cheater box. You can take high tension wire and a transformer and pull as may amps as the transformer, wiring gauge, breaker,ect will allow. If you wire a 240 stove or dryer in a residence a normal 10 gauge wire30 amp on each leg would do. I know RV is different.  Simple 1 leg of 120v 50 amp 240 supplies 50amp the hot side of 30 is 30amp. 20 amps more same voltage. Done!
« Reply #31 on: July 07, 2006, 11:24:37 AM »
I am sorry, but in my opinion house wiring and RV wiring are the same and I really do not understand this statement at all.
« Reply #32 on: July 07, 2006, 12:29:12 PM »
Richard, I agree that house wiring and RV wiring are exactly the same EXCEPT for bonding the neutral which we have discussed to death for years.
Len
Len
« Reply #33 on: July 07, 2006, 01:22:55 PM »
Yes, and that is only due to the different power sources, I believe. i.e. shore, genset and inverter.
Len
Len
« Last Edit: July 07, 2006, 05:17:34 PM by DrivingMissLazy » Logged
prevosman
« Reply #34 on: July 07, 2006, 02:06:38 PM »
The bonded neutral is typically a local code issue and is not a universal practice.
When temporary power outlets are produced the neutral and ground are not bonded, but the provision for bonding is provided with the outlet so the installer can do so to meet the local requirements.
I think the applicable standard for temporary power outlets is UL230 in case anybody needs something to read to get to sleep tonight.
Jon Wehrenberg
Knoxville TN
1997 Prevost Liberty
Pages: 1 2 [3]  All   Go Up
