May 26, 2013, 01:56:35 AM *
Author Topic: windshield washer bottle 5c  (Read 580 times)
christopher
« on: May 27, 2009, 06:01:04 PM »
does anyone have a working windshield washer bottlepump ?
mci wants $138.00
thanks
chris
« Reply #1 on: May 27, 2009, 06:48:46 PM »
Convert it over to the electric type you can buy those in truck wrecking yard for 20 bucks, but if you want the air type I'll check in the shop I had a couple        good luck
« Reply #2 on: May 27, 2009, 06:58:11 PM »
I agree, I love our electric ones! They are great! We purchased ours from IBP, and once we figured out the grounding issue, they have performed wonderfully. I don't miss the Slap, SSSSLLLAAP, SssslAAP, ssssssssllllappp, of the old air wipers. We did rebuild them, and they got better, but they still damaged one of our windshields.
God bless,
« Reply #3 on: May 27, 2009, 07:50:06 PM »
Make sure you get the high pressure/high flow electric pump, or it'll just dribble out your spray nozzles.
Those electric pumps are not created equal.
« Reply #4 on: May 28, 2009, 03:59:05 AM »
   At the same time I changed to electric pumps(separate pumps and controls for each wiper arm). I added "wet arm nozzles" replacing the OEM "below the windshield " nozzles. The wet arm nozzles attach to the wiper arm and lay the water right next to the wiper blade.
    Only thing I need to do is find a couple small check valves for the hoses. They drain all the way back to the reservoir, so it takes a few seconds of pumping before I have water at the nozzles.  Jack
