May 22, 2018, 02:57:48 PM *
Author Topic: How many types of DD-3 are there?  (Read 3758 times)
BG6
« Reply #15 on: June 11, 2009, 04:33:51 PM »
There are ALWAYS two kinds on ANYTHING.
1)  The kind you have.
2)  The kind that everyone else has, for which there are manuals, cheap parts and advice in abundance.
« Reply #16 on: June 13, 2009, 06:03:54 AM »
Tony has it right.
On original install, the pushrod is supposed to be cut to a length that puts the slack adjuster/pushrod angle in relation to one another close to 90 degrees with the brakes applied, and with the brakes adjusted.
In earlier attempts to train drivers, this bit of info was then passed out as how to check your brake stroke..WRONG!!!
First, by eye, a few degrees either side is a whole lot of stroke, and secondly, how do you know the mechanic cut the rod at the right length to begin with? Very inaccurate, for a device so important and that is about an inch of difference between fully right, and fully wrong!
Fredward
« Reply #17 on: June 14, 2009, 10:23:33 AM »
Well i got it back together yesterday. Adjusted the brakes, checked the angle of the push rod to the slack adjuster. Total stroke from released to fully applied is about 1.5". Test drove it and everything works well and it seems to stop better, but thats pretty subjective. I think the old rod was too short. It would bind when fully released.
Life is good.
A few more pictures will follow later, once I download them. I need to work on the generator exhaust pipe now.
Fred
Fred Thomson
