May 25, 2018, 11:23:06 PM *
Pages: 1 [2] 3   Go Down
Author Topic: Help! Need a running 8v71  (Read 7933 times)
« Reply #15 on: June 09, 2009, 05:58:35 PM »
I'm curious if Rodney Monk was able to help?
I was going to have him look at doing some work on my bus, but he had some issues with the city of Fargo so he quit doing that kind of work.
YmeHP
« Reply #16 on: June 14, 2009, 06:33:15 PM »
Will a motor out of a cabover fire/utility truck work in a bus?
« Reply #17 on: June 14, 2009, 06:54:26 PM »
One from a truck will work for you may have to change a few parts from yours to the truck engine like the oil pan      good luck
« Last Edit: June 14, 2009, 06:59:53 PM by luvrbus » Logged
AIRHOG
« Reply #18 on: June 14, 2009, 06:59:47 PM »
I have a 12V71 with a new 740 if that will help.
AIRHOG
YmeHP
« Reply #19 on: June 14, 2009, 07:32:15 PM »
How about a 6v92 from a newer bus? What parts or mods would need to be made?
« Reply #20 on: June 14, 2009, 07:44:43 PM »
If you can buy one from a MCI with the cradle the only part you would need is a longer drive shaft the 6v92 is shorter than a 8v71
YmeHP
« Reply #21 on: June 14, 2009, 07:58:49 PM »
Thanks guys, I never knew how hard these things were to find!
Fredward
« Reply #22 on: June 17, 2009, 09:12:25 AM »
The one in South Dakota is gone. But you might try Dan Holter at Rochester City Lines 800-368-4874 or Nimco in N.J. 800-526-8055.
Fred
Fred Thomson
Don Fairchild
« Reply #23 on: June 17, 2009, 09:32:16 AM »
There not really that hard to find, It finding one at the price you want to pay.
Jack has one down in Florida that would get you out of a bind and you know it was well maintained.
I sent you a pm
Don
poppi
« Reply #24 on: June 17, 2009, 09:42:12 AM »
try
  http://www.westerntruckparts.com/products/
 They have 2 used ones at around 3500 plus core charge. plus shipping
   You will have to change the pans. neither have jake brakes.
 HTH
  Skip
Fredward
« Reply #25 on: June 17, 2009, 09:56:20 AM »
Keep in mind one from a truck is going to require a number of bolt on changes. The water pump/front motor mount is different, the alternator drive camshaft is different, the oil cooler and pump might be different and the rear flywheel/geartrain housing is probably different as well. All are bolt on changes, I"m sure and you already have all the right stuff.
FRed
Fred Thomson
Don Fairchild
« Reply #26 on: June 17, 2009, 03:47:40 PM »
Airhog;
what do you want for the 12V71. Is it a turbo or natural
Don
uncle ned
« Reply #27 on: June 17, 2009, 03:49:20 PM »
Don
Think we can get this in the back of huggy,   may solve the heating problems
ned
4104's forever
6v92 v730
Huggy Bear
Don Fairchild
« Reply #28 on: June 17, 2009, 04:39:07 PM »
hey, if you have the time and money we can do anything. I'm thinking t-drive with twin turbos at around 650hp. duel charge air's and rad's with there own hyd. fans  Then you could haul a big trailer with all those bikes and your truck
What do you think
Jerry32
« Reply #29 on: June 17, 2009, 04:42:24 PM »
You can make anything work if you throw enough money at it... Jerry
1988 MCI 102A3 8V92TA 740
Pages: 1 [2] 3   Go Up
