May 22, 2018, 07:19:48 AM *
Author Topic: DDEC Fuse  (Read 2275 times)
homermandy
« on: July 07, 2006, 06:27:44 PM »
I was checking my fuse from the battery to the DDEC and ATEC. It looked pretty rusty. I went to take off the screws at the fuse and it literally crushed in my hand. Now, what size fuse was it:)? Amperage wise. I need to get one in the morning. Any special kind? I assume a normal fuse will work. Thanks
PS. This also may be my intermittant trans do not shift issue. Will keep you posted.
1991 Eagle 15
homermandy
« Reply #1 on: July 07, 2006, 06:34:22 PM »
I checked online at some schematics and it looks like it might be a 15A fuse?
1991 Eagle 15
RTS/Daytona
« Reply #2 on: July 07, 2006, 06:45:39 PM »
ECM Power connector pins F/E (circuit 240) to one 20 amp fuse
ECM Power Connector pins A/B (circuit 241) to one 20 amp fuse
Pete RTS/Daytona
homermandy
« Reply #3 on: July 07, 2006, 07:33:33 PM »
Thanks Pete. Interesting, it looks like 2 wires were connected to a single 20A fuse then. Unless I am missing a feed from the batteries. Thanks
1991 Eagle 15
