April 25, 2018, 01:42:47 PM *
Author Topic: Safety information regarding what is igniter's temperature of combustible  (Read 1643 times)
Sojourner
« on: July 08, 2006, 05:31:00 AM »
Concern about how much heat to start a Fire.
Whenever combustible material (including engine fuel or gas-vapor or wood or rubber or plastic or dry-grass) is near heat source of 700° F or higher is to shield it or move it away from it at a greater distance.
Remember this in your mind & heart...
“That All Combustible Material in general Will Beginning To Ignite at 700+°F”
So whenever you rework or add or remove heat-shield or limited-ventilation is to be-care-full using combustible material near it.
Also avoid any low temperature plastic material over-head in 250°F area or compartment. It will beginning in time to sagging or drips (about 400°F+ for most plastic) on to higher temperature parts….if over 700°F…then you will have fire on hand.
Remember “insulation” is only a “delayer” substance or system to control heat or cold respond to whatever want to be cooler or hotter.
Vertical air-flow between non-conducting metal shield & compartment will reduce heat transfer. Greater the air-flow the less heat transfer to next surface or conductor.
For your information….diesel engine’s compression-stroke has to obtain air temp of at least 700°F with fine vapor fuel-mist before any explosion to take place. Greater cranking-speed the higher compression-temperature.
Been there & done many tests & retired at General Motor Engineering Staff at Warren, Mi. Remember the national news report about “Grass Fire from GM cars” with catalyst converter in 1974-5! That was one of my jobs to find the results. As long all cylinder is running but one.…you are safe from making grass fire.
FWIW
Sojourn for Christ, Jerry
plyonsMC9
Big Wheels Turnin'
« Reply #1 on: July 08, 2006, 07:50:45 AM »
Thanks Jerry - Excellent post!
Best Regards, Phil
Northern Arizona / 1983 - MC9
