June 20, 2018, 11:39:55 PM *
Author Topic: What is "heat PEX"?  (Read 1639 times)
« on: July 02, 2009, 04:45:39 AM »
Nick mentioned using "heat PEX" for radiant heating in a thread, but I never got an answer about what heat PEX.
Is "heat PEX" the same as oxygen barrier PEX?
scanzel
« Reply #1 on: July 02, 2009, 05:21:38 AM »
Go to www.pexsupply.com this site shows a huge supply of Pex products and explains the different Pex tubing and shows pictures of also. You will be supprised what you can find info on if you just Google.
Steve Canzellarini
Berlin, CT
1989 Prevost XL
« Reply #2 on: July 02, 2009, 05:59:39 AM »
None of the websites really specifically call anything heat PEX like Nick called it.  I am pretty sure the oxygen barrier PEX is the same thing, but trying to verify.
Oxygen barrier PEX is carried at Menards so I wouldn't have to get it from a plumbing supply place like Nick recommended, if it is the right stuff.
FloridaCliff
"The Mighty GMC"
« Reply #3 on: July 02, 2009, 06:38:27 AM »
On the site Scanzel linked to, they refer to all of the heating Pex as oxygen barrier.
http://www.pexsupply.com/PEX-Tubing-223000
Cliff
Mark Twain
« Reply #4 on: July 02, 2009, 07:33:28 PM »
Hi Brian,
Yes Heat PEX is Oxygen barrier pex. I use a Heat Pex that is rated for 220 deg.'s .
If a safty should fail in a boiler system, the 220 deg. pex wont MELT and rupture.. Shocked
Just makes good sense not to flood a customers house should a disaster occur!
