May 27, 2018, 02:51:27 PM *
Author Topic: Bi-fold to Sedan door question...  (Read 1150 times)
travelingfools
« on: July 05, 2009, 07:03:09 PM »
Ok, so Ive got the bi-folds off and my plates ready to weld in to hang the door. Ive also got my bottom hinge on. My problem is that I cant locate the molding for the sedan door and my welder is comming over wed to weld the plates in. Will the door shut with the by-fold trim/molding so we can test the door once the plates are tacked in ? Also, this has gone to easy (so far)..Is there anything else Im missing ?
Hartley
« Reply #1 on: July 05, 2009, 07:10:03 PM »
I had to remove the bi-fold molding because the Plug style of the sedan door wouldn't fit.
Try the door in the hole first, You may get lucky..
I used a jack and nylon straps to jocky the door into place and had to climb
through a window to look from the inside....
Yeah.. Mine looks like crap and I went the cheap way and used a stainless
piano hinge. That's what happens when you have to do everything by yourself.
Here is an old picture after I hung the door.
« Last Edit: July 05, 2009, 07:17:56 PM by DrDave-Reloaded » Logged
Tom Y
« Reply #2 on: July 05, 2009, 07:35:37 PM »
What plates are you welding in? Mine bolted right in, I had to remove the seal for the bi fold. The door I bought was sprung some, nothing some blocks of wood and a 12 pound sledge couldn't fix. Are you putting the air lock on?  Good luck  Tom Y
Tom Yaegle
« Reply #3 on: July 06, 2009, 07:26:55 AM »
Yes, tell us about the need to weld!
The mounting points for both styles are present in all examples that I've seen.
But, I've not seen them all!
travelingfools
« Reply #4 on: July 06, 2009, 09:21:04 AM »
Mine is an ex-NJT and does not have the tabs for hanging the door. I was warned about this and got the ones from the donor bus where I got the door.
