February 25, 2018, 11:12:51 AM *
Author Topic: 102a3 Voltage Regulator @nd question  (Read 1860 times)
fairlang
« on: July 10, 2006, 08:26:08 AM »
Thanks to Nick and Stan for reply on first post.  In the 3rd bay is where I have all my utilities and may have to remove my tanks to get to the regulator. Stan, the only cover that I remember is the one covering the air tank. Is this the one that you are referring to ?When I look at the rear bulkhead from the outside, in front of the drive wheels, I cannot see where the regulator may be.  Thanks for any and all help.
Beatenbo
1993 MCI 102 C3 Cat Power
« Reply #1 on: July 10, 2006, 10:35:56 AM »
Should be at top in corner where the tunnel holds all your air lines and cables. Normally it is a cover that is hinged with vent holes. My fresh water tanks is in last right bay and I fixed so I could drain and remove if I need to get to voltage regulator. Good Luck, Charlie
