June 21, 2018, 04:49:33 PM *
Author Topic: 4905 trans oil level ?  (Read 1696 times)
3408cat
« on: August 01, 2009, 03:11:44 PM »
I have a 4905 with a standard transmission, do you check the transmission oil level with the engine running, or with it stopped Huh Thank you for your input, Bill.
roadrunnertex
« Reply #1 on: August 01, 2009, 04:53:57 PM »
Per the maintenance manual the engine must be stopped/shut down.
Note: The transmission uses the same oil as the engine.
jlv Tongue
3408cat
« Reply #2 on: August 01, 2009, 05:01:39 PM »
Thanks for help, I was alittle worried when I checked it running and there was no oil on the stick, but with it shut down it was showing almost full.
