April 23, 2018, 04:28:16 PM *
Author Topic: 4905 fuel gauge  (Read 5715 times)
3408cat
« on: August 01, 2009, 03:16:43 PM »
Did 4905A buses have a fuel gauge ? Mine does not, and I don't see a sending unit on the fuel tank. Any ideas on putting one on it ? Thanks, Bill.
roadrunnertex
« Reply #1 on: August 01, 2009, 04:48:30 PM »
The fuel gauge was a option for the GMC 4905's.
There were two types from GMC one on the drivers instrument panel.
The other was located at the fuel fill area behind the fuel service door with a momentary on switch to read the fuel quantity inside the tank.
I guess that there might be a aftermarket fuel gauge for your 4905 but I am not aware of who might sell them.
jlv Tongue
3408cat
« Reply #2 on: August 01, 2009, 05:08:08 PM »
Thanks for the info, I felt a little silly asking about the location of the fuel gauge, I guess I'll just make some kind of stick to check it.
gomer
« Reply #3 on: August 02, 2009, 06:21:07 AM »
If you will look on the floor above the fuel tank[inside] next to the side, you will find a plate that will expose your fuel tank where the sending unit installs,if it hasn't been covered. A universal gauge will work just fine in there and run a wire to the dash  and put a gauge in where it normally goes.  Make sure of the voltage, mine is 24v.. Oh open the fuel door and look at the floor and you will be able to see where the hole is.
Gomer
as you slid down the banister of life,may the splnters point the other way
TRUST IN GOD ALWAYS. riverjordanmusic@aim.com
Gomer
3408cat
« Reply #4 on: August 02, 2009, 10:58:30 AM »
The trap door in the floor has been covered. I'm seeing two round parts on top of the tank. I'm guessing that the one thats incorporated into the filler neck is the whisle and the other one is where the sending unit goes. It has a large foam type tube -a/c ? over it. It has a round neck facing forward, but I can't quite reach inside of it to know if it is just a cover, or a sending unit. Generally where the ones without gauges just sent though with a flat plate covering the sender hole in the tank ? I'm hoping its a sending unit already in place, but I don't want to wreck the ducting to find out that its not a sending unit.
trailblazer2
1999 Thomas Saftliner MVP
« Reply #5 on: August 03, 2009, 05:53:21 AM »
 Bill;
 I have one of these gauges that I am not going to be using. It does not have the sending unit,just the gauge.It is made by ISSPRO,and it is still in the box.I will take $20.00 plus shipping,if that will benefit you.Those 4905's are the best bus to convert ,just let me know if I can help!
Bill
"I will place no value on anything I have or may possess,except in it's relationship to the kingdom of Christ"
David Livingston
« Reply #6 on: August 03, 2009, 06:36:07 AM »
Bill,
   If you can shine a light in there and see the top of the plate, if it is a block off plate it will only have 5 screws the attach it to the tank (around the perimeter). If it is a sender it will have an insulated terminal for the gauge wire and a ground terminal, plus the 5 mounting screws.  Jack
« Reply #7 on: August 03, 2009, 07:12:32 AM »
I would guess that whether or not it was ordered with a fuel gauge that the wiring is in place anyway.
3408cat
« Reply #8 on: August 03, 2009, 02:30:27 PM »
What I'm seeing looks like a sending unit. It's not just a flat plate. It's dome shaped with a round neck facing forward. I can't reach into it to feel if there are terminals for the wires or not. The a/c ducting feels like it is going to rip if I pull on it any more to get to the possible sending unit.
roadrunnertex
« Reply #9 on: August 03, 2009, 05:02:17 PM »
My 4905 has the same part on the top of the tank forward of the fuel fill neck and it's not a sending unit for a fuel gauge.
My thought it is a vent for the tank.
The maintenance manual and the parts manual does not have a illustration of this
 part. Cry
jlv
3408cat
« Reply #10 on: August 03, 2009, 05:31:16 PM »
Could the part I'm looking at be the whistle ?
roadrunnertex
« Reply #11 on: August 03, 2009, 05:38:48 PM »
It's not the whistle I know that.
jlv
3408cat
« Reply #12 on: August 03, 2009, 06:13:22 PM »
Well, I guess without a sender there isn't any sense in getting a guage, I'll just keep track of my mileage and go from there, thank you all for your help, Bill.
« Reply #13 on: August 03, 2009, 06:35:34 PM »
use a yard stick or a stick that will bend and you can put marks on.. hint: don't use a felt tip marker to make the marks.
roadrunnertex
« Reply #14 on: August 04, 2009, 08:05:35 AM »
The Greyhound PD4107's had a 165 gallon fuel tank's and the range in miles between refuel was 900 miles.
The Greyhound PD4106's had a 140 gallon fuel tank's and the range in miles between refuel was 800 miles.
So to be safe refuel your 4905 every 600 to 700 miles and you will be sure that way not to run out of fuel on a trip.
Works for me. Tongue
jlv
