February 24, 2018, 11:58:36 PM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Tank help please!!!!!  (Read 6819 times)
mahala1
« Reply #30 on: August 28, 2009, 09:22:03 PM »
See if this is what you need. http://www.plumbingsupply.com/bulkhead.html Maybe thread the tank, and screw the fitting in the tank without using the backup nut, add a nipple and connect to your pipe with rubber hose to absorb vibration and prevent cracking.
« Last Edit: August 28, 2009, 09:30:10 PM by mahala1 » Logged
« Reply #31 on: August 29, 2009, 05:30:08 AM »
Thanks, Paul. That helped, and I can picture it now.
Mahala, thanks for the link. We have considered something like that.
God bless,
cody
« Reply #32 on: August 29, 2009, 06:28:27 AM »
wow, mahala, how can they justify 180 dollars for a 4 inch fitting.
« Reply #33 on: August 29, 2009, 12:56:02 PM »
I have a three inch one like that one that I never used.  I couldn't figure out a way to tighten the fitting.  My tanks are polyethylene.  I was going to cut a hole and then cover it with more polyethylene, but a local plastics welder said the plastic would eventually crack.
I got my fitting from Indelco Plastics and it was between $30 and $40.  A lot less money than plumbingsupply.com.
Hartley
« Reply #34 on: August 29, 2009, 08:37:35 PM »
Darned BBS software erases a post on file size errors (192k )
I had the instructions and tools listed too!
Get one of these. ( your favorite plumbing supply house )
Cut in half ( not split )
Take clamps off.
Check to make sure the rib where the clamp was slips into the hole
and locks in place. Get your 3" PVC or ABS and cut a stub that you
will insert into the rubber sleeve once it is in the hole. ( use silicone )
on final assembly. Once the rubber is in, Shove the PVC or ABS into
the rubber fitting which expands it and seals the hole.
These are available to fit 2 through 6 inch pipes.
For a 3" use a 3.5 Inch hole saw. For a 2" use a 2.5 Inch hole saw.
This allows for a flexible joint which is not subject to breaking from
vibration or flexing. Oh.. Also since the stub is sticking down into the
top of the tank a bit, It gives you a little wiggle room to get things lined up later.
I have never had a fitting break or leak using this method.. It's almost too easy..
« Last Edit: August 29, 2009, 08:41:06 PM by DrDave-Reloaded » Logged
« Reply #35 on: August 30, 2009, 05:59:09 AM »
Thanks a lot guys. I think we have it just about figured out, thanks to you all.
God bless,
Pages: 1 2 [3]  All   Go Up
