May 21, 2013, 11:48:32 PM *
Author Topic: Can you folks post your Solar Panel installs and recommendations.  (Read 3470 times)
Jerry32
« Reply #15 on: September 01, 2009, 06:36:14 PM »
Niiice JERRY isn't it great what money can buy . I like you systembut can't afford it as living on the government SSI. I have what I could scounge up cheap 6 80 wat panel and a blue sky controller. They will keep the fridge and satellite internet going and maybe some TV too. Jerry
1988 MCI 102A3 8V92TA 740
gfcgfc1
The Fleur de Li's
MC7 as I found her 'The Fleur de Li's'
« Reply #16 on: September 01, 2009, 07:28:52 PM »
Hello ,thanks for the original post question.A BIG way to go to Jerry Campbell nice answer and a GREAT set up on his coach.            THANK YOU VERY MUCH .I am making my own "baby steps" GFC
1972 MCI MC-7 4speed manual  Happy to have this unit.Sunny Arizona
« Reply #17 on: September 01, 2009, 08:59:37 PM »
I have seen a few postings that some have installed a few solar panels on your bus.   In the larger picture the dollar spent might not be a wise investment.
That is an astute observation.  Or maybe an understatement.  It's hard to make definitive statements about the cost-effectiveness of solar, because it depends on so many factors that vary greatly from installation to installation, such as the amount of incident sunlight, installation angle of the panels, ability (or lack thereof) to track the sun, plus the variability in the lifetime of the panels, which will be impacted by environmental considerations (snow, heat, lack of cool airflow underneath, sleet, etc.) as well as mechanical stresses from the installation, such as on a moving bus.
That being said, on average for motor coach installations, solar is not a cost-effective way to make electricity.  So you really have to want to do it for other reasons, such as being able to leave the coach parked someplace while you are away for a few days, weeks, or months without having to worry about the batteries, or you want to be able to park in some national park campgrounds where generators are prohibited or severely restricted, or you just prefer to keep your generator operation to a minimum for the peace and quiet.
But if you want to keep all your batteries topped off and your fridge maintained as a luxury>> what are your real world experiences?
We have "330 watts" of panels, along with an MPPT charge controller to maximize the available output.  For us, if we are parked where the panels get good light for most of the day, that's enough to run the fridge (high-efficiency Novakool 24-volt model, 7.5 cubic feet) pretty much indefinitely, and the air compressor as well if we are not actually on board using air, plus perhaps a Fantastic or two on thermostats.  So we think nothing of taking off for a week or two with a fridge full of food, but we do turn off all unnecessary and parasitic loads, and we leave the genny on auto-start as a precaution (it has not had to run).
Real life, of course, is different, and using things like the coffee maker, microwave, computers, and occasionally the TV, not to mention using air by flushing the toilet and opening and closing the plug door means we need to run the genny every few days for a few hours to charge back up;  the solar extends that time by a little bit, but the natural variability of daily life makes the amount of extra time we get very difficult to calculate.  (We average one hour of genset run time per day when boondocking in temperate weather, starting on day three -- the first two days are provided courtesy of the 50DN alternator.)
Die-hard desert rats have arranged their rigs and their lives to use a bare minimum of electricity, and those folks can get by on solar alone indefinitely, but it is a spartan lifestyle and requires alternative technologies (chiefly propane) for such things as refrigeration.
I put the wattage in quotes, because that is the "nominal" wattage of the panels under ideal conditions.  Ideal conditions are never encountered most places, and especially on a bus.  A 110-watt panel might generate 90% of that figure on a crystal clear day in the Arizona desert while aimed directly at the sun at high noon.  When you allow for other latitudes, lower incident angles (more atmosphere to traverse) throughout most of the day, inability to keep the panels directly aimed at the sun, etc., the number drops to 60% or less of that figure.  If there are times when it is not sunny out, even less.  If there is a shadow of any kind on even a small fraction of a panel, that panel's output will drop almost to zero.  The list goes on and on.  So in real world conditions, you can expect to see perhaps 20%-40% of ideal "rated" output across the daylight hours.
What I use for the purpose of "napkin" calculations is to use 50% of rated output times 8 hours in the summer, 6 in winter, to get an approximation of available output (in sunlight).  So my "330 watts" of panels might provide a single kilowatt-hour of electricity on a good day.  That's about 40 amp-hours on my 24-volt plant.  For comparison, we use 125-175 amp-hours per day on average, if we are in temperate weather where we need neither air conditioning nor heat.
That's all the panels that would fit on our roof, BTW, given that we have three roof airs, three Fantastics, a MotoSat dish, a roof hatch, and a 7'x7' deck up there.  If you have a clear roof, with today's technology you could squeeze perhaps 3.5 kW (nominal) of panels onto a 40' coach, ten times what we have.  But bear in mind, at 50% average performance, that's still less than a single household 15-amp circuit can produce.  Still, we can (and have) run our whole coach indefinitely on a single house circuit, so it can be done.  Mind you, that much solar will cost north of 20 grand for the panels alone, before figuring mounting hardware, cables, charge controllers, and other miscellaneous bits -- figure a quarter c-note for a complete installation.  (At today's prices, BTW, that would buy you 10,000 gallons of diesel, which would run the average 6.5kW genset for about 20,000 hours -- 833 days straight, or two years, three months, and 12 days.)
Hope that gives you some useful perspective.
bobsw
« Reply #18 on: September 01, 2009, 09:28:04 PM »
We have 4 130 W panels with 4 8d agm batteries and a blue sky controller. We boondock all winter in AZ and this set up has cut our gen. use to about 1hr  a day we love it. Discount Solar in Quartzsite AZ. designed and installed our system. They were very good to work with, reasonably priced and very professional with their install. I would recommend them to any one that is looking for solar even if you just have a question give them a call they will help you out.
73 MCI-7
Zeroclearance
« Reply #19 on: September 01, 2009, 09:57:30 PM »
Thanks to all that have posted!!    Can you guys post the brand of your solar panels..   I was looking at the Sharp units, but someone told me that they aren't "designed" for RV use.  Hence no warranty.   A friend pointed me to www.kyocerasolar.com
I guess that most of us fall into two camps> ones the really boondock, and others that want to keep the diesel noisemaker at a minimum when on the road.    Sean I'm thrilled to hear the 50DN gives you a good head start...    (sidenote to Sean>How's the new turbo doing")     I'm thinking about installing 8 panels to keep the fridge running and a few electronics.    Again, when you pencil in the numbers running the genset seems to be the smart thing.  Having solar assistance is a luxury!   To bad we couldn't get a tax credit for our buses.
« Reply #20 on: September 01, 2009, 10:20:06 PM »
We have the 24-volt (nominal) Shell Solar (formerly Siemens) panels.  The 110-watt units we have are discontinued.
None of the "good" panels is designed for RV use, including the Kyocera.  I think you will find that RV-specific panels have lower energy density and higher per-watt cost than standard panels.  If a panel quits, you take it back to the distributor -- I suspect they will replace it under warranty without asking too may questions about where it was installed unless it is obviously damaged from physical abuse.
We never run the genny on the road -- the 50DN provides all the power we need.  Remember, this is a 7 kW alternator -- half a kW of solar is hardly going to make much of a difference on the road.
The turbo seems to be humming along, thanks.  Of course, it was before, too, right up until it self-destructed...
...  To bad we couldn't get a tax credit for our buses.
Well, ahem... we did take the tax credit.  We read the fine print, as did our accountant, and nothing in there excluded a moving house, so long as it was our house, which it is. YMMV, as they say.
« Last Edit: September 02, 2009, 09:53:14 AM by Sean » Logged
oldmansax
Tom & Phyllis
'82 Bluebird Wanderlodge PT40
« Reply #21 on: September 02, 2009, 05:13:42 AM »
I just want Sean's bus............
 Grin Grin Grin Grin Grin Grin
TOM
'82 BlueBird WanderLodge PT40 being rebuilt
Delaware
DON'T STEAL! The government hates competition!
Jerry W Campbell
« Reply #22 on: September 02, 2009, 08:32:04 AM »
http://sunelec.com/
$1.98 a watt for 130 watt panels. Cheeeeeeeeep
Jerry
LarryN 4106
« Reply #23 on: September 02, 2009, 09:49:41 AM »
I have found Mark Nemeth's website very helpful in sorting out low voltage issues.
http://bart.ccis.com/home/mnemeth/tech.htm
« Reply #24 on: September 02, 2009, 10:11:47 AM »
Make me an offer...  Grin
http://sunelec.com/
Those are extremely cheap.  Many of the other panels on their page are also far below market, which is right now running from $3-$5 per watt for first-quality panels over 100 watts (smaller panels run more per watt).  My figures in a previous post here were based on last year's market, which was even higher at close to $6 per watt, where they will be once again, no doubt, when the economy recovers.
So cheap, in fact, that I am suspicious.  Now it may in fact be the case that they are arbitraging panels based on market dynamics, as they claim at the bottom of the page, or it may be that they are picking up panels at manufacturer's fire sales, typically because the panels are discontinued, surplus, or second-quality.
There's nothing wrong with saving money this way, of course, as long as you recognize the limitations.  If you have discontinued panels, as I do, then you need to know that if one panel breaks, finding a direct drop-in replacement may well be impossible, possibly compromising your investment in mounting hardware and labor.  Surplus panels typically have a more limited warranty.  And factory seconds may have sub-standard performance.
As always, YMMV.
Of course, there is a distinct possibility that this outfit simply had a giant warehouse full of panels when the market tanked, and now they are slashing prices below cost to pay the rent or liquidate their inventory before they have to pay another year's tax on it.
David Anderson
Diamond Lake St Park, Oregon
« Reply #25 on: September 02, 2009, 11:47:14 AM »
I've always wondered and never seen it addressed.  What happens if you're unfortunate enough to get caught in a hail storm?  Will it damage these panels on top of the coach?
David
Jerry W Campbell
« Reply #26 on: September 02, 2009, 03:57:45 PM »
Hi David,
    I have never heard of hail damaged solar panels. But, I have seen hail so big it destroyed everything outside in the neighborhood so I'm thinking it is a possibility. Your supposed to be able to walk on the Kyocera panels I have But I wouldn't dare.
Jerry
84dime
« Reply #27 on: September 02, 2009, 08:08:16 PM »
I as well am interested in this subject. I have 2 solar panels on my newly acquired bus. I have no clue how they work or how big they are or even if they work. Can someone tell me how these things work and what is required to make them work? Also how do i check to see if mine are working?
Thanks-Josh
Joshua Chapin
PD-4104-3946
Salem,OR
« Reply #28 on: September 03, 2009, 04:29:03 AM »
Ummmm....  sunshine?
Seriously, that's what is required to make them work. Sunshine!
Ok, so that's a smart assed answer, but basically correct. When sun shines on your panels, they produce electricity. Your panels should be connected to a charge controller, which is in turn connected to your batteries. Locate those pieces and you should be able to figure out if they are working. You might have to look up some instructions on your particular charge controller.
Follow the wires....
Brian Diehl
« Reply #29 on: September 03, 2009, 05:38:43 AM »
I've done some initial looking into adding some solar panels to my house and to my bus.  I ran across this panel:
http://us.sunpowercorp.com/downloads/product_pdfs/business/SunPower_315ewh_com_en.pdf
However, I've not been able to find it available for sale in a few simple google searches.  Outback Power does not carry it either and said they don't see any reason to carry it.  SunPower does make some pretty impressive claims on the power capacity of this panel.  From a space efficiency standpoint this panel would be worth a small premium.
Thoughts anyone?
