May 24, 2013, 05:43:36 AM *
Author Topic: Wipers and Dash Boards and Lights, Oh My!  (Read 642 times)
frontman
Frontman
« on: September 08, 2009, 06:36:58 AM »
I was wondering where the best place to buy an electric wiper kit for my Eagle would be.  I have it down to tubing right now, so this would be the time to make the change.
The dash I have has holes all over it from the different things that were put in the bus over the last 20 years.  I would like to replace it with an after market dash.  Is there such a thing, or will I have to make one?
Also thinking about going with all LED lights.  Is anyone using these and do you like them?
Well, I'm off to weld some tubing!
Chad
« Reply #1 on: September 08, 2009, 06:55:18 AM »
Chad, your better off to remove all the gauges and glass over the dash the model 15 has a good layout but if you want a aftermarket Richard at R&M sells its, also if you need a steel player for you band he is good at that also lol.
Craig at Sliver Eagle has the wiper kit and LED kits for your bus all though I am not impressed with the LED's also International Bus Parts in Fl also the wiper kits, fwiw if IBP still uses the plastic arms on theirs I would not buy theirs
« Last Edit: September 08, 2009, 07:07:23 AM by luvrbus » Logged
frontman
Frontman
« Reply #2 on: September 08, 2009, 07:48:07 AM »
I will look things over today and see if I can salvage the dash.  I should call Richard though, steel players are hard to find Grin
I have been trying to call Silver Eagle and I can't get through.  I am using the number off the web site.
Chad
RTS/Daytona
« Reply #3 on: September 08, 2009, 05:26:31 PM »
check out----->
http://www.busconversions.com/bbs/index.php?topic=12346.0
