May 23, 2018, 10:00:19 AM *
Pages: 1 2 [3]  All   Go Down
Author Topic: Usuable Fuel Gallons from fuel tank  (Read 5252 times)
bcaddel
« Reply #30 on: September 11, 2009, 07:57:44 PM »
Buswarrior
Is it the general consensus that a stick shift will average 1 mpg above an automatic?
Even at that expense, from my experiance I think it may be worth it.
Bob
Bob Caddel, Las Vegas Nevada
1971 MC7, 8V71, Allison MT654
« Reply #31 on: September 11, 2009, 08:18:20 PM »
in busnut use, the practical issue is how many miles will be driven each year?
Very few busnuts drive far enough for anything to really matter in fuel economy terms in the choice of transmission.
An auto driven well will match or beat a stick driven poorly.
Drive both like the devil is chasing you (in other words, revenue service with a paid wheel holder) and the spread will hold.
Pick the transmission that your co-driver is likely to be happy with?
Once you get into the Allison World family of transmissions, and the automated manuals, everything gets blurred some more.
« Reply #32 on: September 13, 2009, 11:06:51 PM »
I just returned from a 5,000 mi trip in my 4104 with 671 and 4sp manual. I crossed the Rockies and Cascades two times each and climbed some pretty impressive grades.
I found that after climbing in 4th gear and getting the engine around 200*F or slightly higher that when I shifted down into 3rd (or 2nd a couple of times) that the temp would immediately go down.
I assume this is caused by the fact that the lower gear makes the engine work less and the fan is turning faster and the coolant is circulating faster.
This same thing would apply when running in 4th instead of 5th, the engine is working less in the lower gear.
Pages: 1 2 [3]  All   Go Up
