April 19, 2018, 03:03:51 AM *
Author Topic: ATEC  (Read 2220 times)
homermandy
« on: July 16, 2006, 03:26:58 PM »
Can someone decipher a date code from an Allison ATEC box?
Date code is 0045
Just trying to see when the ATEC was manufactured.
1991 Eagle 15
« Reply #1 on: July 16, 2006, 05:05:29 PM »
Hi Homermandy,
I don't know allison's date codes but, I deal with alot of date codes in my busisness. And from a standard code, I see May 5th 2000'
Just a hunch but, may be so!
Nick Badame-
« Reply #2 on: July 16, 2006, 05:53:40 PM »
Here's a SWAG.. the 4 could be the month...2000, April, 5th.
Our engine date codes are just reversed from standard....either way, it looks like a mid 2000 trans.
My dos centavos, JR
BTW, what trans is it?
homermandy
« Reply #3 on: July 16, 2006, 06:28:49 PM »
Interesting. It is an Allison HT746.  1991 Eagle 15. What's interesting is that those coaches at that time which were converted by Florida Coach had the ZF trans.  The engine which I had rebuilt was a Reliabilt in 2000.  They must have put an Allison in at that time... When did the ATEC HT746 come out?
1991 Eagle 15
Kristinsgrandpa
« Reply #4 on: July 16, 2006, 06:49:52 PM »
  My service manual covers all HT and HTB 700 Electronic Controls series transmissions.
  It covers the HT741, HT 748, HT 755 CR, HTB 755 CR, HT 755 DR, and the HTB 755 DR.
 It doesn't mention th 746 and it was published  1 May, 1990
The 746 then came out after it was published. (apparently)
Ed
Sammy
« Reply #5 on: July 16, 2006, 06:58:40 PM »
1993 Orion transit bus had an HT748 with ATEC , mounted behind a 6V-92 TA with DDEC.
Hope this might help you.
Sammy  Cool
homermandy
« Reply #6 on: July 16, 2006, 07:18:50 PM »
Thanks.  It is probably a remanufactured HT746 since the ATEC code is from 2000?
1991 Eagle 15
