May 25, 2018, 04:07:23 AM *
Author Topic: Weight of MCI 5C ???  (Read 2057 times)
Timkar
« on: September 13, 2009, 07:25:35 PM »
I have tried the Internet with no luck. Looking at a 1978 MCI 5C without engine and trans for less than scrap price.
Any idea of possible weight of unit? I need to get it towed if I buy it and need to know what size truck required to haul it.
I checked and there are no Landolls in immediate area.
Thanks...Tim  Huh Huh
Cawston, British Columbia
« Reply #1 on: September 13, 2009, 08:08:06 PM »
a big twin axle tow truck will do the job. Get one with a wheel snatcher and pull the axles.
christopher
« Reply #2 on: September 14, 2009, 03:10:50 PM »
mine weighs 26000 lbs fully loaded.
chris
mci5c
where are you towing from?
« Reply #3 on: September 14, 2009, 03:42:08 PM »
Figure the engine and tranny were probably close to 4000 lbs.
Timkar
« Reply #4 on: September 14, 2009, 06:58:11 PM »
I was figuring around 20K lbs as it has been stripped. Can't find a tandem tow truck in immediate area so may
have to check further away for one. It is in Penticton, BC and I need to move it about 40 miles southwest.
Thanks for the responses....Tim
« Reply #5 on: September 14, 2009, 07:13:06 PM »
There should be a provincial towing association you could access to find something as close as possible.
« Reply #6 on: September 14, 2009, 09:21:06 PM »
Should be an easy tow since the engine/transmission are not in it you won't have to pull the axle shafts or the drive shaft-just hook up, attach lights and air lines and go!  A normal axle lift tow truck should do (you might be able to get by with a 2 axle heavy duty tow).  Good Luck, TomC
