May 27, 2018, 09:04:38 AM *
Author Topic: Remco Transmission Lube Pump  (Read 3289 times)
usbusin
« on: September 21, 2009, 04:45:34 PM »
Has anyone used a Remco Transmission Lube Pump for towing a car four-wheels down?
What has been your experience?  Was it reliable and could you monitor it from the bus?
Would appreciate your input as I am looking at some vehicles that are not towable 4 down.
Gary D
redbus
« Reply #1 on: September 22, 2009, 04:33:20 AM »
I have installed several Remco Lube pumps.NEVER had one come back with a problem.You can monitor it from the Bus.
Terry
www.awayweare.blogspot.com/
« Reply #2 on: September 22, 2009, 04:55:50 AM »
Although we do not use a Remco pump (our Grand Cherokee does not require it), I know several people that use them.  I have not heard of any problems.  Jack
Eagle
1985 Eagle
« Reply #3 on: September 22, 2009, 05:02:13 AM »
You will need to check with Remco as the pump does NOT work with all vehicles.
usbusin
« Reply #4 on: September 22, 2009, 07:19:52 PM »
Thanks for your input.  I have been reading both pros and cons on different boards.  Seems that some have had the pump quit and the transmission ruined.  Others love them.  Decision time!
Thanks again.
Gary D
« Reply #5 on: September 23, 2009, 10:40:15 AM »
Any pump can fail.  I would not have a problem using the Remco but I would want some kind of alarm up front to be sure is is working, maybe as simple as an oil pressure switch.
« Reply #6 on: September 23, 2009, 11:27:08 AM »
My friends shop installs them and they are very reliable.  His installs always include a low pressure alarm that sounds in the coach.
TOW IT WITH THE ENGINE RUNNING!
« Reply #7 on: September 23, 2009, 12:17:42 PM »
There was a system a few years ago where you could over fill the transmission for towing.  When you wanted to drive the car, it would store the excess fluid in a reservoir of some kind.  Don't know if that would work with the newer transmissions.
jjrbus
MCI5C/N Ft Myers FL
« Reply #8 on: September 23, 2009, 05:52:02 PM »
Most of the Ford Windstars cannot use a pump. Don't assume it will work check with Remco.
