alltech
« on: September 23, 2009, 07:35:16 PM » |
I am coverting my phneumatic windshield wiper motors to electric motors. I have looked at a couple of conversion kits, but they all involve a certain amount of fabrication. Quotes for the kits range from $500 to $1300. From my point of view if I have to do any fabrication to make these kits fit, I might as well do it all. I am looking for a source to procure a couple of 12 volt dynamic park drive motors. Does anyone have any suggestion on what motors to use and a supplier?
Regards,
Ross
1988 102C3 8V92
Bob Belter
« Reply #1 on: September 23, 2009, 08:08:21 PM » |
Ahoy, Ross, Freightliner -- maybe 'millenium  ' stuff is the windshield wiper system that I used for the conversion on my Eagle -01. Reasonable price from Valley Truck Parts 800 598 5715 Fresno CA. Serouus comercial truck components, and you will be able to get parts for a long time. You must fabricate the mountings, but they work great, and have nice controls. I now -- no longer -- wish to take a hammer and smash through the windshield to slay those frantic air wipers!!!!! Enjoy /s/ Bob
« Reply #2 on: September 23, 2009, 08:21:03 PM » |
I bought an electric wiper conversion from IBP the first year we were at Rickreall. The system came from Autex in New York. I know this because I ended up dealing directly with Miguel at Autex in order to get it working. Mine came with some switches that had been on the shelf for a very long time in a very damp location. Ultimately I was able to buy the switches locally at NAPA but it took a while to determine what the problem actually was. I was well pleased with Miguel's support and assistance and once working the wipers have worked flawlessly. PM me if you want more details but I'd call Miguel if I were you.
R.J.(Bob) Evans 1981 Prevost 8-92, 10 spd My websiteOur weblogSimply growing older is not the same as living.
alltech
« Reply #3 on: September 23, 2009, 09:03:04 PM » |
Thanks for the information
I will check both these options
Regards,
Ross
1988 102C3 8V92
« Reply #4 on: September 24, 2009, 04:42:06 AM » |
I just bought an IBP kit from a guy who had Newell. He was trying to install these but they wouldn't fit. He had started to modify the mounts before he figured out they wouldn't fit, so IBP wouldn't take them bak. I'll probably have to modify them to fit my MC9. The invoice was over $1400!!! I got them for substantially less than that
Offline
« Reply #5 on: September 24, 2009, 04:49:05 AM » |
You might want to check with Fred Hobe in Madison, FL. He has a kit that is great and much lower priced than IBP. He will also install them if you take your coach to his place. Jack
Melbo
« Reply #6 on: September 24, 2009, 06:03:30 AM » |
I got mine out of a wrecked semi truck for 100 dollars but as noted took some fabrication and engineering to get it to work as desired.
Melbo
If it won't go FORCE it ---- if it breaks it needed to be replaced anyway Albuquerque, NM MC8 L10 Cummins ZF
muddog16
« Reply #7 on: September 24, 2009, 06:27:15 AM » |
I agree with Bob, Miquel at Autex is the man when it comes to electric windshield wiper systems!
« Reply #8 on: September 24, 2009, 06:34:43 AM » |
There is a outfit in Oregon called AIM that will build the system for you for less than 1/2 of what IBP charges with wet arms , no plastic on the arms and better motors.
« Reply #9 on: September 24, 2009, 02:15:12 PM » |
mccarlk
« Reply #10 on: September 24, 2009, 05:50:24 PM » |
what about about wiper motors and arms from a international school bus?
treat every day like is your last, just make sure you dont spend all your money,in case its not!!!!!!!!!!!!!!
mccarlk
« Reply #11 on: September 29, 2009, 03:28:01 AM » |
any thoughts on the international bus wiper motors, theres a yard with a few retired busses they are parting out , will these be stong enough?
« Reply #12 on: September 29, 2009, 05:22:17 AM » |
I think they would work ok if they are pantograph setup for the double arms. You'll have to fab brackets to fit your own install. Actually, I thought Jack Conrad used wipers from an old schoolie, but maybe I'm mistaken.
« Reply #13 on: September 29, 2009, 06:30:22 AM » |
Guys the air wipers can work as good as electric they have been on these buses for 20 to 50 years without any maintenance done what so ever except changing the wiper blades. Service the motors,arms. replace the control valves and install a regulator before the air supply to keep the supply at the same pressure 90 lbs or lower depending on the speed you like and you will be amazed how good they work. There is a delay action available for air also for those who would like it
« Last Edit: September 29, 2009, 06:59:37 AM by luvrbus »
Eagle Andy
« Reply #14 on: September 29, 2009, 05:19:29 PM » |
Hey Clifford , I was inpressed with mine after I reworked mine (one down one to go) It was rather easy . Anyway were can I get a delay ? Thanks Andy
