June 19, 2018, 07:17:29 PM *
Author Topic: Vacuum flouresant Gauges  (Read 1960 times)
SPICEY MEATBALL
« on: September 29, 2009, 12:17:31 PM »
Hey all,was wondering if any one has had any experience installing these, or any thoughts or ideas for a readable dash whilst driving at nightime, thanks all.  Wink
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=390/category_id=71/home_id=59/mode=prod/prd390.htm
Ex 1989 Model 15 Predator class War Bird owner
« Reply #1 on: September 29, 2009, 12:25:00 PM »
I have no experience with those, but since you asked about readability, I would avoid digital gauges in favor of analog.
With analog gauges, a quick scan without actually registering the readings on the brain, tells you everything is OK or not OK.  With the digitals, you have to actually read the number and the brain calculate the condition.
Digital is probably OK for volt meters where a tenth of a volt is meaningful, but for everything else, I prefer analog.
Len
skihor
« Reply #2 on: September 29, 2009, 06:58:29 PM »
I like analog also. I turn them so when everything is at proper setting all the needles point up. Looking at them while setting is wierd but while running with a quick glance you can spot something wrong.
Don & Sheila
BCM Webmaster
« Reply #3 on: September 29, 2009, 09:36:58 PM »
I agree with going analog.  Another problem with digital gauges is how they present numbers that may be rapidly fluctuating.  For example, reading a digital tach on the fly can be frustrating.
If you are definitely wanting a high tech look, maybe consider going with ones that presents an enhanced analog experience using straight or curved rows of LEDs, with color coded sections to denote fault conditions.
« Reply #4 on: September 30, 2009, 04:51:44 AM »
If you really want to get fancy, get a set of ProComp gauges like the NASCAR drivers use. The really bright backlighting changes colors with different readings. Green or blue in normal range, orange/yellow in warning range and red in danger range. The settings are adjustable.  Jack
SPICEY MEATBALL
« Reply #5 on: September 30, 2009, 07:57:07 AM »
Jack,that could be what I am looking for. I  admit the high tech digital ones are very enticing and easy to read but also very pricey, I do however like the traditional analog gauges,Nascar gauges are pretty bright, no doubt a price tag to match, I just don't want to have to use the Mag light to see them at night.
« Reply #6 on: September 30, 2009, 08:40:21 AM »
Van, it would help if you removed your sun glasses at night LOL or we could change your engine over to a DDEC and buy a Glass Dash from Jim that is one accurate digital setup.
I am tempted since I got approval from the banker last year but she may have changed her mind by now being she knows that a engine swap would be involved.
« Reply #7 on: September 30, 2009, 10:25:05 AM »
Clifford,
Aren't those dashes like 10K? I thought that they were fairly pricey.
God bless,
Chuck Newman
« Reply #8 on: September 30, 2009, 07:50:25 PM »
Yes it is pricey.  But actually, the Glass Dash is all digital in operation, but the display shows "digitized" analog instruments.
1989 MCI 102A3, Series 50, DDEC III, Allison 740D
