June 20, 2018, 08:09:27 PM *
Author Topic: where can i find insulated ducting? not the round stuff  (Read 2369 times)
RickB
« on: October 19, 2009, 07:05:28 AM »
I am looking for a supplier of RV type small dimension rectangular ducting. Thinking about replacing ALL of my non insulated round dryer vent type ductwork. I can't believe the previous owner spent all that money doing a conversion and then put this stuff in. Yuck.
Also, on my suburban furnaces where the gas supply line comes through the shell leaks like sieve. What can I safely use to fill in that gap? Thought about that yellow expanding stuff but was worried about flammability and fumes.
Any thoughts?  Aluminum tape?
This is gonna be a pain no matter how I look at it.
Ray D
« Reply #1 on: October 19, 2009, 07:29:09 AM »
right here
http://www.insul.net/prod_ultraduct.html
I made my own with the 1/2" foam sheets with foil on both side from home depot
Ray D
« Reply #2 on: October 19, 2009, 07:30:59 AM »
what we used   for ducting was take a 4by8 foiled faced foam sheet and scour one side at each bend and make the rectangle we needed then tape the  sides at the joint. also use a lot of spray foam to fill cracks and help protect things from rubbing...I insulated my bay doors by drilling 5/16 holes on a 6inch grid on the inside then spray foam till it came out the next hole etc..really helped the cold floor and total energy use. had to chip out around the release handles.
« Reply #3 on: October 19, 2009, 09:42:59 AM »
Be careful injecting the canned foam through a small hole.  Some of that stuff will expand aggressively enough that it will deform the void you are putting it into.
Chuck Newman
« Reply #4 on: October 19, 2009, 10:01:20 AM »
Another alternative which will allow use of existing vents.
http://www.grainger.com/Grainger/items/5E271
http://cgi.ebay.com/4-Flexible-Insulated-duct-work-by-Thermaflex_W0QQitemZ300277217655QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item45e9eab977
http://cgi.ebay.com/Fantech-FIDT4-Flexible-round-insulated-duct-4-x-25_W0QQitemZ230312025137QQcmdZViewItemQQptZCeiling_Fan?hash=item359faa9c31
« Last Edit: October 19, 2009, 10:13:28 AM by Chuck Newman » Logged
1989 MCI 102A3, Series 50, DDEC III, Allison 740D
muddog16
« Reply #5 on: October 19, 2009, 02:33:56 PM »
It's hard to beat the Ultra Duct, price and the ease of installation are amazing......anything else would be.....a Red Green nitemare!   Honestly, that stuff is awesome......there are some photo's of my installation on my site listed at the bottom.......you make the decision......"we report you decide"........... Grin Making transitions are actually to easy..........!
Pat
1982 Prevost LeMirage
8V92TA/HT754
« Reply #6 on: October 19, 2009, 03:23:21 PM »
Hi Rick,
4" round insulated flex duct is readely available at HD.
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051&productId=100396934&langId=-1&catalogId=10053
Air flows through round ducts with less resistance anyway...
Good Luck
dbenck
« Reply #7 on: October 19, 2009, 07:14:40 PM »
Rick, I can make anything you need at our shop, if you want galv. steel
or aluminum. Maybe when I look at your A/C  system ?
David Benck
prevost82
82 Prevost 8V92ta 6 speed
82 Prevost Marathon XL
« Reply #8 on: October 20, 2009, 11:12:53 AM »
I make all my ducts and T's / 90's out of 1/4" ridge insulation that had foil on one side, it was a house wrap product. The stuff works great and fast to build.
muddog16
« Reply #9 on: October 22, 2009, 05:02:40 AM »
Ron, that stuff is workable just like real metal you can bend it on a sheet metal brake too! All you need is a razor knife and foil tape, and a straight edge to make nice cuts, they actually made my "T's" for me, my total cost for the bus was about $170 including shipping.  It took about 3 hours to install the system, minus the transitions.  I have 3 duotherm heat pumps (roof tops). If you follow their instructions for duct sizing I can't imagine it not working well and looking like a quality installation!
Pat
8V92TA/HT754
« Reply #10 on: October 22, 2009, 05:35:30 AM »
   We used UltraDuct. Great stuff to work with. I cut with a straight edge and utility knife, scored with a screen spline installation tool, folded and taped the seam with aluminum duct tape.
    We purchased ours from Innovative Energy, Inc, Lowell, IN 800-776-3645.  We picked ours up at there place (4x8 sheets), but they will cut it into 2x4 sheets so it can be shipped via UPS/FedEx.  I dealt with Ron Rado (VP & Gen. Manager)   Jack
