February 17, 2018, 07:35:46 PM *
Author Topic: Pex for Webasto/Proheat  (Read 6724 times)
« Reply #15 on: November 25, 2009, 05:02:32 AM »
Do you guys use fittings for every 90 bend?  Trying bend 90's with that stuff is like fighting a damned python and you need a boat anchor to hold it in place; well almost.......
Ray D
Yes. Whenever you do a 90, you need to use a fitting. I am not sure what would happen otherwise Shocked. I guess it would be to big of an arc, and look kinda rough with just a bend, and not fitting.
FWIW
God bless,
scanzel
« Reply #16 on: November 25, 2009, 05:26:34 AM »
Fittings are not to be used in the floor because of possible leaks, this is why they sell coils of 1000' so that the tubing can be one continuous loop. Go to www.pexsupply.com they carry just about everything you could possible need. Fittings should be either in a wall for access if necessary or in accessible areas.
Steve Canzellarini
Berlin, CT
1989 Prevost XL
« Reply #17 on: November 25, 2009, 05:31:03 AM »
There are special metal or plastic bend supports for making a 90 without a fitting.  It does take up a bit more space than a fitting, but no leak possibilities.
scanzel
« Reply #18 on: November 25, 2009, 05:38:58 AM »
Yes you are correct, they are recommended so the pex doesn't kink when doing a 90 or a 180 in radiant loops.
Steve Canzellarini
Berlin, CT
1989 Prevost XL
« Reply #19 on: November 25, 2009, 05:43:36 AM »
Guys you are plumbing a bus not a house use the fittings to relieve the stress common pratice in the RV world in the 1 mil +coaches and it has never been a problem why would they sell the fittings strap in down and worry about other things but do it your way
« Last Edit: November 25, 2009, 06:08:44 AM by luvrbus » Logged
TexasBorderDude
« Reply #20 on: November 25, 2009, 06:44:27 AM »
I need a part number or source for "Heat Pex"  I don't find any rated over 180 degrees.  Have chcked Vanguard, (now Viega) Pex Supply and researched the net.  Nick, What am I missing?
Just Dallas
« Reply #21 on: November 25, 2009, 08:16:30 AM »
Removed
« Last Edit: July 17, 2010, 03:15:52 PM by Now Just Dallas » Logged
TexasBorderDude
« Reply #22 on: November 25, 2009, 08:25:29 AM »
Maybe I was unclear, according to the link below the rating is 200 degrees...  I'm looking for the 240 degree rating Nick mentioned.
Dallas, please send me that Google link.... Huh
http://www.thermapextubing.com/technicalinformation.asp
ThermaPEX® Tubing Ratings
    * ThermaPEX® Tubing carries following ratings as issued by Plastic Pipe Institute: 73° F: 160 psi - 180° F: 100 psi - 200° F: 80 psi
Just Dallas
« Reply #23 on: November 25, 2009, 09:56:59 AM »
Removed
« Last Edit: July 17, 2010, 03:15:22 PM by Now Just Dallas » Logged
sweeney153
« Reply #24 on: November 25, 2009, 10:51:11 AM »
I got mine from
Radiantec Company
PO Box 1111
Lyndonville, VT 05851
1-800-451-7593
www.radiantec.com
They have been in business a long time and are very helpful. they will help design your layout or the whole system I just started talking to them about my bus. I have no connection to them other then being a happy customer, but I highly re-comend them. I deal with Don Vance DonV@Radiantec.com
Kevin
Warwick NY
1964 4106-2703 8V71 Spicer 4 speed
TexasBorderDude
« Reply #25 on: November 25, 2009, 11:05:46 AM »
I just went to http://www.google.com and typed in "Heat Pex"
It came up with this:
http://www.google.com/#hl=en&source=hp&q=heat+pex&aq=f&aqi=g-p1g9&oq=&fp=25d2df88517031cf
661,000 sites found, some of which will have what you want.
Mighty cleaver of you Dallas!  I looked at most of the links on the first several pages yesterday.  Please let me know when you've found 240 degree pex, 'cause that's the real object of the search!
Just Dallas
« Reply #26 on: November 25, 2009, 11:49:04 AM »
Removed
« Last Edit: July 17, 2010, 03:13:38 PM by Now Just Dallas » Logged
TexasBorderDude
« Reply #27 on: November 25, 2009, 12:37:43 PM »
Dallas, yep Google works that way... type in words and it searches.  I am skeptical that there is such a product as 240 degree pex and asked Nick for a part number or link to such product.  None of the specs I can find exceed 200 degrees and since Nick is the expert I asked him to share his sources.  So far you or no one else has come up with it... Google will come up with search results  (as will Peanut butter Pex too!)
Why?  I'm plumbing a hydronic heating system and want a loop to tie into my engine coolant.  200 degree plus coolant circulating and if there was such a thing as a "Heat Pex"  rated at 240 degrees (as was the claim in one of the first posts of this thread)  I'd like to use it.  Seems to be like the mystical Hong Kong doctor, Dr. Chang, who rebuilds hymens.  People talk about it, but nobody's seen it done!
Just Dallas
« Reply #28 on: November 25, 2009, 03:15:20 PM »
Removed
« Last Edit: July 17, 2010, 03:13:12 PM by Now Just Dallas » Logged
TexasBorderDude
« Reply #29 on: November 25, 2009, 03:52:39 PM »
Whoa, whoa, whoa!  I apologize for any offense and appreciate all help given... I'm just trying to find the 240 degree stuff if there is any such thing.
