May 20, 2013, 11:19:41 AM *
Author Topic: Air Beam Leak Repair  (Read 3254 times)
Burgermeister
« Reply #15 on: April 16, 2006, 11:33:57 AM »
You'll get a better appreciation of the task if you go to Gumpydog's site and look at the pictures.  The airbeams are rectangular tubes about 6x6 or 6x8 and 36-40" long  buried in the frame structure  below the floor and inside the wheels.
It can be done - anything can if you're determined enough!  but it's alot of work.   My "California" MCI-9 had a huge amount of fine silt all over this area that served as a "sponge"  making sure the corrosion continued long after the rain was gone.  Haven't "tested" for leaks yet,  but I'll let you know if any show and what I do to address the problem.
Melbo
MC8 under construction
« Reply #16 on: April 16, 2006, 06:06:24 PM »
Like the old expression goes
Given enough time and enough money you can fix anything
Not to say it is always worth it
Melbo
