February 18, 2018, 12:06:41 PM *
Author Topic: Curious  (Read 1434 times)
Bosshosssport96
« on: July 25, 2006, 09:13:31 PM »
A few days ago,I received my 8V92T,still bolted on was the clutch,pressure plate and throw out bearing,will these items work on a 8V71????Frank 4501-082
« Reply #1 on: July 26, 2006, 09:58:43 AM »
I believe the bolt pattern is different.
Happycampersrus
« Reply #2 on: July 26, 2006, 12:38:46 PM »
The flywheel end of the 8V92 crank is larger than the 8V71.  Undecided. The flywheels will NOT interchange. You can try and see if you can use the parts depending on which 8V71 flywheel you have. There are a couple different size clutches used and you might just have a match on the bolt pattern on the pressure plate.
Dale
« Last Edit: July 26, 2006, 12:47:33 PM by Happycampersrus » Logged
Bosshosssport96
« Reply #3 on: July 26, 2006, 06:19:40 PM »
Thanks for the responses.........Frank
