June 19, 2013, 12:07:39 PM *
Author Topic: Isle width question?  (Read 3780 times)
bryanhes
Eagle Model 10 "For Now"
« on: January 10, 2010, 05:58:13 PM »
I have spent much of my weekend modifying or changing the drawings of my bus. I like an open feel to the interior but am having a little difficulty with isle width in regards to my dining booth and counter.
My question: Is there a minimum standard width in an isle? I was at a Monaco dealer several months ago and he mentioned 26". I want it as open and as wide as possible for moving around but some things would have to be changed. At this point I have 21" between my booth and kitchen counter which is not enough for me. So I will be making some changes.
Any codes?
Bryan
« Reply #1 on: January 10, 2010, 06:06:45 PM »
Ours is 3 feet wide. Our old couches allowed a 2 foot walkway, which was too small. The 3 feet is a good width.
God bless,
David Anderson
Diamond Lake St Park, Oregon
« Reply #2 on: January 10, 2010, 06:07:46 PM »
My clearance from dinette to counter top is about 26, an arbitrary number that felt comfortable for my behind.  Do what feels right to you, no codes I've ever heard mentioned here.
David
bryanhes
« Reply #3 on: January 10, 2010, 06:18:41 PM »
I liked the idea of having a bit of an "L" or "U" shaped counter but with the placement of the booth it hinders that. The only real choice I see is to make my counter more straight and that would give me 35" vs. 21". You can see the interior in the sketchup drawing I posted earlier today. Some things are a little tougher than others to put together the way you want with the space you have  Roll Eyes
At least I have all this cold weather to keep me inside to play with it  Grin
Bryan
Fred Mc
« Reply #4 on: January 10, 2010, 06:34:56 PM »
After 20 years of having a booth we changed to a small table and two chairs. What a difference. So much room now. The booth was uncomfortable and took up so much space. Other than that it was perfect.
Fred Mc.
RichardEntrekin
« Reply #5 on: January 10, 2010, 06:37:35 PM »
Marathon does a floor plan I REALLY like with a L shaped dinette. They mount the table top on a slide that will also turn.
So that when you are not occupying the booth, the table pushes in towards the seats and gives a ton of aisle and kitchen space, and when you are eating the table moves to give you space.
The point is that mounting the table surface on a slide and turntable gives you the best of both worlds. I looked underneath and they use a simple hand screw to lock it down in whatever the desired position.
I looked at it REAL close, and I can draw you a sketch if you would like.
Richard Entrekin
95 Newell, Detroit S 60
Subaru Outback toad
Huntington WV
bryanhes
« Reply #6 on: January 10, 2010, 06:47:21 PM »
Fred,
I originally had a bar with an overhang and two chairs. But with a 14 & 12 year old still at home I thought the booth would be more advantageous. I also like having the booth for when you want a place to enjoy a cup of coffee with friends Grin The table and two chairs would be fine if it were just the wife and I but kids can get messy to and I have younger nephews I would not dare let eat on the sofa  Roll Eyes
Richard,
Is it on a website?
Bryan
« Reply #7 on: January 10, 2010, 06:59:54 PM »
102" wide bus. 2.25" insulation with 1/4" plywood over= 97" interior width. Minus 24" kitchen counter top width, minus 42" wide dinette=31" space between which is enough for two people to pass.  Good luck, TomC
« Reply #8 on: January 10, 2010, 07:03:20 PM »
On seated coaches the law is 26" isle. But it's your coach now, do it yer way!
CAROLINABOY
« Reply #9 on: January 10, 2010, 07:33:55 PM »
just remember to take in consideration the refer measurements, so you wnat have to much trouble if you have to replace it.
servant for JESUS CHRIST
cody
« Reply #10 on: January 10, 2010, 07:57:02 PM »
Mostly we went with a 42 inch booth that becomes a wide single bed, the seats are attached to a 36 inch pedestal that serves as storage and also has a nightlight under it that lights up the floor, also wired for internet and outlets, it gives us a 36 inch isle that can be wider if needed, you flip the table, pull a pin and the seats swing to the side allowing the refrigerator to move past it if needed.
bryanhes
« Reply #11 on: January 10, 2010, 08:08:20 PM »
Cody,
Do you have a raised roof? It may be just the angle of the picture but it looks taller than normal.
Bryan
bryanhes
« Reply #12 on: January 10, 2010, 08:13:11 PM »
Anyone else have any pictures they want to share of dining and counter?  Grin
Bryan
cody
« Reply #13 on: January 10, 2010, 08:25:48 PM »
No raised roof, just the way the picture worked out I guess, we have about a 75 inch ceiling height. A couple of pics for ideas.
« Reply #14 on: January 10, 2010, 08:26:40 PM »
26" really?  For my first real trip in the bus I kept two of the original bus seats up front side by side.  That aisle sure felt narrow!  The second trip I removed the bus seat on one side and installed a captain's chair.  Much nicer with more room now.
I lost one seat, but there is still seating for 10 plus the driver.  If there are 8 or 9 people are all sitting up front it gets pretty tight.  Usually a few are sleeping in bunks so it isn't as bad.
