{{{2/13/10 I am updating this thread - see page 3}}}
{{{2/17/10 results updated see page 5}}}
Well, the saga continues.
First I would like to thank all of the folks who have called to ask how the replacement engine installation is going. I have tried not to clog this great bulletin board with all my trials and tribulations. I have told several folks that this bus and I have a love/hate relationship. For the past few months it has been the latter. Every component I touch seems to delight in frustrating me and consuming huge amounts of my limited resources!!!!
If you are really bored, you can follow all of the gory details of this saga in the following threads:
http://www.busconversions.com/bbs/index.php?topic=13609.0http://www.busconversions.com/bbs/index.php?topic=12915http://www.busconversions.com/bbs/index.php?topic=12668http://www.busconversions.com/bbs/index.php?topic=12599.0OK, now I need some help in thinking my way through the my latest problem (low turbo boost). I just took the first drive around our subdivision (fairly big hills) and about the highest boost I saw on the SilverLeaf was 4.5 pounds (it should have maxed out at around 20-25 pounds). I think the RPM was high enough to get good boost and I was at full throttle.
I have pulled the cold side and the turbo spun very well. This was my “old” Series 60 turbo that had 54K on it. The turbo that came with the replacement engine had the bypass turbo, but the mechanism did not feel like it was working. If it makes any difference, I am using my “old” ECM.
The first thing that folks think about is fuel starvation and fuel filter issues. I use the FuelPro 382, which tells you if there is an issue (via the clear glass bowl). Along that line, I had to work to get the flow established to the filter when I first tried to fire up the engine, but it seems fine now. I can look at fuel flow rate on the SilverLeaf. Sitting in the shop, and stabbing the throttle shows a spike in the flow of about 5 GPM (no load). That would be flow into the engine and would not include the fuel bypassed back to the tank.
I have looked at the several silicone flexible connectors that connect all of the metal tubing to and from the charge air cooler. I did not see any obvious sources of pressure loss. If all else fails, I will make a couple of caps for that plumbing and test for leaks with compressed air. That will test the whole system including the charge air cooler.
So, what great ideas do you all have about the low boost?
In addition to the turbo boost problem, my AutoShift range shift solenoid is throwing a code. Thus I have gears 1-5, but not the top side. I don't think that is a huge issue.
However, all of these issues put the last nail in the coffin as far as taking the bus to the big Quartzsite bash. We are thinking about driving the service truck and staying in one of the two motels in town. Part of that decision will be based on some pretty major health issues going on our daughters families. Pat is not sure she can leave with all of that turmoil going on.
