January 16, 2018, 01:39:39 PM *
Author Topic: Synthetic Transmission Fluid?  (Read 10714 times)
« Reply #15 on: January 21, 2010, 12:19:18 PM »
For those interested, I did a little searching and found that Valvoline Maxlife ATF meets Allison's TES 295 spec for synthetic ATF.  It seems it can be gotten for about $20./gal (maybe quart bottles though).  The cost is really close enough to C4.
« Reply #16 on: January 21, 2010, 01:10:20 PM »
No Valvooline products are on Allison's list of TES 295 approved fluids.  Does Valvoline have an approval number from Allison?  The PDF on Valvoline's website only lists the fluid as "suitable for use in Allison TES-295 and TES-389 applications".
Per http://www.allisontransmission.com/servlet/DownloadOnDemand?ApplicationID=155&DownloadID=5, for the B500 Allison recommends fluid change (with Transynd) at 48 months or 300,000 miles general or 150,000 miles severe service, whichever comes first.  The filter is to be changed at 36 months or 75,000 miles.  For the HT 700 series Allison recommends changing the fluid (With Transynd) at 48 months or 100,000 miles general duty or 24 months or 50,000 miles for severe duty.  Filter change intervals for the HT 700 series are all over the map depending on what filter you have.
« Reply #17 on: January 21, 2010, 01:13:24 PM »
I Allison says to change standard fluid at 25000 miles/12 months, Transynd at 50000 miles/24 months, and a mixture of both at 50000/24 months.  They define mixture as the quantity of oil left while changing to Transynd.  Could be they just want to encourage you to buy their stuff, I guess.
You're correct for the HT 700 series when using the severe duty schedule.  The B500 can go 48 months on Transynd fluid for general or severe usage.
« Reply #18 on: January 21, 2010, 07:15:00 PM »
Brian,
You bring up an interesting issue.  Allison has about 5 manufacturers that they approve for TES 295.  However, there are many others that list TES 295 as one of the specs they meet.  An oil distributor I spoke to claimed that the various manufacturers must by law comply with whatever specs they list on the container.  As I understand it, the manufacturers would have to pay Allison to be added to their TES 295 list, so many just state that they meet that spec instead.  Amsoil is not Allison approved, but they list the specs of their product as compared to Transynd to show there is really no difference:
PHYSICAL DATA
AMSOIL Torque-DriveŽ Synthetic Transmission Fluid (ATD)
Castrol/Allison TransyndŽ Synthetic Automatic Transmission Fluid
Physical Data
   Torque-Drive™    TranSyndŽ
Kinematic Viscosity @ 100°C, cSt (ASTM D-445)
   7.41    7.36
Kinematic Viscosity @ 40°C, cSt (ASTM D-445)
   37.14    37.29
Brookfield Viscosity @ -40°C (cP)
   8411    8400
Density @ 60°F (lb/gal)
   7.038    7.047
Flash Point °C (°F) (ASTM D 92)
   230 (446)    232 (450)
Pour Point °C (°F) (ASTM D 97)
   -55 (-67)    -55 (-67)
Four Ball Wear Test
(ASTM D-4172B: 40 kg, 75°C, 1200 rpm, 1 hr) mm
   0.45    0.45
Copper Corrosion (150°C, 3 hr)
   1B    1B
Spectrographic Analysis
Boron (ppm)
   133    136
Calcium (ppm)
   28    29
Phosphorous (ppm)
   230    235
I am not an expert on this, but find it reasonable that if companies like Valvoline list their product as TES 295 compliant, it probably is.  However, I would really appreciate being set straight if I'm wrong.  Thanks
Overview
MaxLife DEX/MERC ATF contains a blend of superior base oils and a unique additive package to help extend the life of transmissions with over 75,000 miles. It is formulated to maximize transmission performance, reduce transmission wear, and improve and maintain smooth shifting longer than conventional fluids. MaxLife DEX/MERC ATF is compatible with new and rebuilt transmissions and will not void new car warranties.
Recommended for use where DEXRON, DEXRON II, III and VI, Toyota T-IV and WS, MERCONŽ, MERCONŽ SP and LV, Allison TES 295 and 389, Nissan Matic-D, Matic-J and Matic-K, Honda Z-1 (except CVT), Mercedes NAG-1, Mitsubishi Diamond SP-II and SP-III and many others are required.
« Reply #19 on: January 21, 2010, 10:31:10 PM »
The Amsoil fluid is priced at $43 a gallon so as I might as well use Transynd for the price.
I found a letter from Valvoline that specifically says they have not submitted Maxlife ATF to any manufacturer for testing.  That doesn't mean it is not TES 295 compliant.  They just haven't paid for the testing.  Since my Allison isn't under warranty there is no requirement to use a TES 295 fluid.
Marcus
« Reply #20 on: January 22, 2010, 03:19:33 AM »
I have amsoil in my 740. It works great and as said before tranny runs cooler. Marc
« Reply #21 on: January 22, 2010, 06:10:06 AM »
Heat should never be a problem with a Allison anyway if everthing is according to Hoyle mine runs within + or- 5 degrees of the engine temperature.
If I had a newer electronic transmission synthetic would be my choice but for the old HT transmission naw waste of money.
« Last Edit: January 22, 2010, 06:20:40 AM by luvrbus » Logged
« Reply #22 on: January 22, 2010, 09:48:05 PM »
I did some calling around today for TES 295 approved fluids.  Neither International truck dealer I called had Fleetrite synthetic ATF.  They both had Transynd.  The local Mobil distributor had the Mobil Delvac synthetic ATF, but it is $38 a gallon.  The John Deere dealer sells the HD Syntran for $55 a gallon!  The John Deere stuff is listed as made by Castrol.
I forgot to call the Freightliner dealer for a price on Transynd, but last time I bought a gallon it was like $35.  Transynd seems to be as cheap as the alternatives.
I really should change out my Transynd this summer, but I am not looking forward to the cost.
« Reply #23 on: January 22, 2010, 10:07:31 PM »
Brian,
I spoke to the rebuilder I got the transmission from.  He felt the Maxlife would be fine but said he does not prefer synthetics.  He said that regular ATF can give signs of a problem by color and smell while the synthetics may not.  Further, he claimed that he has found that lots of motorhome users prefer C4 motor oil because they say it runs cooler then ATF, which is the main thing I want.  Of course, changing fluid more frequently is not an issue for him since he runs a transmission shop.  I guess at this point I am not sure what to do, but might just use the C4.  It is also possible that oil change intervals can be extended by periodically testing the oil and changing it only when it needs it rather than by a particular schedule.  Anyway, my concerns are going to be slightly different than yours since I am dealing with an ancient 647 instead of one of those new fangled machines.
« Reply #24 on: January 22, 2010, 10:53:27 PM »
Since I have a B500 I really want to run synthetic since everyone says they don't last as long as the old HT 700 series.  I see a lot of coaches with B500s advertised with rebuilt or replaced transmissions, but the motor is still original.
« Reply #25 on: January 23, 2010, 05:22:30 AM »
Lin, ask your rebuilder how those motorhome owners knew the transmissions was running cooler.
I'd be thinking rare is the motorhome that has a transmission temp gauge?
It may be that the C4 doesn't come out of the sump smelling burned the way that the other tranny juice does, but that is no indication of a lower temp.
Beware the unsubstantiated words of a tradesman.
« Reply #26 on: January 23, 2010, 08:49:11 AM »
BW,
I'm sure that you are right about not taking unsubstantiated information as gospel.  In many things, all one can do is collect whatever is available and make a choice.  However, although the engineering and professional information would seem to be the primary source, anecdotal information can be just as important.  Experience may trump theory.  In many things, I keep looking until I am thoroughly confused, then flip a coin.
