June 18, 2013, 02:58:58 PM *
Author Topic: ? what is the air bag number for 4106 buses?  (Read 1010 times)
« on: February 13, 2010, 04:14:03 PM »
Pondering the possibilities and was wondering what the firestone and bridgestone rolling lobe air bag #s are for both the front and back.
Thanks as always.
p.s. this query relates to the possibility of using rolling lobe set up as my air beams decay.  So far I have only seen people (my bus as well) using block off plates and double convoluted.  It occurs to me that the rolling lobe bits are all over the place and maybe they could be changed in.....maybe less $$$ maybe smoother ride.
mikelutestanski
Mikes Metal Mistress
« Reply #1 on: February 13, 2010, 04:55:54 PM »
Go to the mohawk industries website and check out their kits to get the part numbers you need.
    Regards and happy bussin   mike
  1972 MCI 7
  L10 Cummins  B400R  4.625R
« Reply #2 on: February 14, 2010, 05:43:28 AM »
I tried that but as I don't have the original 4106 part #s it's a no go.  Basically the bag #s for a 4106, and the rolling lobe seat # for a 4106 front and rear.
Just Dallas
« Reply #3 on: February 14, 2010, 06:24:38 AM »
Removed
« Last Edit: July 15, 2010, 11:52:13 AM by Now Just Dallas » Logged
RTS/Daytona
« Reply #4 on: February 14, 2010, 07:33:25 AM »
does this help
http://www.firestoneindustrial.com/pdfs/Aftermarket/BUS_014.pdf
http://www.truckspring.com/air-springs-bus_995.html
« Reply #5 on: February 14, 2010, 08:19:01 AM »
Thanks guys,  now I have a little figuring to do.
wildbob24
« Reply #6 on: February 14, 2010, 12:35:33 PM »
ZUB,
I can give you a Firestone # for the fronts: W01-358-5406
And a Goodyear # for the rears: 1R10-089 (OEM # G1019358)
Bob
P8M4905A-1308, 8V71 w/V730
Duluth, GA
