May 23, 2018, 10:15:26 AM *
Author Topic: Engine Comparisons  (Read 9469 times)
Handyjim
« on: February 23, 2010, 10:56:41 AM »
Is there a chart (or website) that does engine comparisons?  I'm new to this bus thing. Tried to do a search and couldn't find what I want.  6v72 versus 6v92 versus 8vXX; etc. with and without turbo, etc.  And where does a series 60 fit in the picture.  When I start my bus hunt, I want to have an idea of what to look for.  Power, performance, economy.  Am I asking the impossible to want the information distilled into an easy to use format?
I'm tired of  my Class A gasser crawling up hills, and having a love affair with every fuel pump. Smiley  So when I begin my purchase search, I want to get something that will make me happy to start, rather than face a repower in the conversion process.
JCorey
Looking, looking, looking
Toward a Conversion
PP
Will & Wife
« Reply #1 on: February 23, 2010, 12:39:01 PM »
Hey Handy, I'm sure more knowledgable gents and ladies will chime in on this question, and I think you will find that everyone likes something about each available option out there. I personally held out for an 8V92 simply because the series 60 were too expensive at that time.(Pre-recession LOL) Good luck in your search, Will
RTS/Daytona
« Reply #2 on: February 23, 2010, 12:48:37 PM »
try--> http://www.adieselengine.com/new_page_1.htm
and see attached file: it's a Canadian STATIONARY engine study (short form / long form) - has some usefull info -->
« Reply #3 on: February 23, 2010, 01:05:01 PM »
6V-71 and 6V-92 are virtually the same engine externally.  The 8V-71 is a bit shorter then the 8V-92 because of the big crankshaft vibration dampner on the 8V-92 on the front of it.
Big block engines include Cummins NTC/N14; Caterpillar 3406/C15/C16, 3408; Detroit Series 60.
Small Block engines (read a whole lot easier to install) are Cummins M11/ISM, ISL, ISC; Caterpillar C12, C13; Detroit Diesel MBE 4000.
Good Luck, TomC
Tom Y
« Reply #4 on: February 23, 2010, 02:12:42 PM »
Jim, If you are hoping to get better mileage from a bus you will be disapointed. No idea what you get, but most here are in the 6-9 range. Some are moving up the hills but a lot are not.  Tom Y
Tom Yaegle
Handyjim
« Reply #5 on: February 23, 2010, 02:17:06 PM »
Would anything be wrong with a series 60 and B500 tranny in a 102D3?  Except maybe the price! Smiley  I know I won't get any better mileage than in my Southwind Gasser (7-7.5 mpg) but maybe I can get up a hill, and have m ore usable space.
JCorey
Toward a Conversion
RickB
« Reply #6 on: February 23, 2010, 02:37:18 PM »
Tom C
I have had a number of folks tell me that the actual block of the 8V71 is 2" longer is it just the dampener/balancer that makes it longer?
without stealing this thread, why wouldn't the cradle for the 71 work for the 92? oil pan, oil cooler, i thought none of these were interchangeable.
Rickb
divinerightstrip
1990 Le Mirage XL
« Reply #7 on: February 23, 2010, 02:59:49 PM »
« Last Edit: February 23, 2010, 03:27:37 PM by divinerightstrip » Logged
The Bus Girl
« Reply #8 on: February 23, 2010, 03:25:20 PM »
Rick, it is the crank and the oil pump that make a 92 longer the bare block on the 71 and 92 are identical in length so are the heads.
The 8v92 weighs several hundred pounds more than a 8v71 also
I have some stuff that will work for a front mount I just need a photo of your 71 series mount and bet a coke we can make one work for you.
« Last Edit: February 23, 2010, 04:14:14 PM by luvrbus » Logged
« Reply #9 on: February 23, 2010, 03:25:51 PM »
Greyhound went from MCI 9 to 102, then they wanted to go back to the MCI 9, This was not possible so MCI made the MCI 12 which is practically the MCI 9 with a diffrent power train.
I would look for a MCI 9 with a 6v92TA and Allison 740, Not the power of a 8v92T but with the 6v92TA you are able to keep the rpm up high were a Detroit likes it.
You would get a MCI 9 at a good price.
PS My MCI 9/Allison gives me  5 mpg if Im lucky plus a little. I think you will get 6 to 6.5 with the 6v92TA.
« Reply #10 on: February 23, 2010, 07:25:53 PM »
Tom Y speaks with great wisdom!
You will not be saving any trips to the fuel pump and now diesel is a LOT more than gas in my area.
« Reply #11 on: February 23, 2010, 07:48:00 PM »
I'm so old that I remember arguing about the difference between a 327 versus a 350 Chevy! If I remember right.... A 327 large journal crank in a 350 block with 307 heads!!!  Grin But in all actuallity, no more miles than most of us cover it doesn't make much sense or cents to be laying out a bunch of $$$ to get 8 miles a gallon instead of 6. Probably a better idea to wait for a good tail wind!! Grin And in all honesty if I can make my bus live another  20 or 30 thousand miles I'll be happy. Others may and probably do cover more miles than I plan on. Then again I'm just starting and who knows! It all depends on each of our plans.
« Reply #12 on: February 23, 2010, 09:54:43 PM »
On our last trip to Las Vegas pulling the car I got just over 6mpg at 58mph cruise. The best mileage I've ever gotton was 7.5 with a serious tail wind.  Good Luck, TomC
Tom Y
« Reply #13 on: February 24, 2010, 04:28:55 AM »
Jim, I was not trying to talk you out of a bus. Just warning you of the comparisons about mpg and hills. I sure we would all like to see another member with a bus. Buy the best bus and drivetrain you can afford and enjoy. I say if you can get a 4 stroke. Others will will say stay with the old Detroits.   Good Luck  Tom Y
Tom Yaegle
cody
« Reply #14 on: February 24, 2010, 04:57:06 AM »
With mileage being about the same, the safety factor should be concidered, a bus is far safer and will usually live longer than a factory unit.  In both cases the driver will be the first at any accident.
