May 18, 2013, 02:09:21 PM *
Author Topic: warning on fuel filters  (Read 1806 times)
white-eagle
« Reply #15 on: March 06, 2010, 05:16:06 AM »
Tom, you probably have something like the PS120 type filter (http://www.parker.com/literature/Racor/14401_Rev_-_PS120_Series.pdf).  If so, there is a gasket and I doubt you will be able to run without it.  If this is not your filter, just shorten the link and look at other Parker/Racor filters.  These types of filters are generally self-priming, but the pump will pull air without the gasket when you need high fuel flow rates.  As you see from the picture, the bowl is a screw on.  My guess is that the person changing the filter did not get it on tight.
an added note, the o-ring was on there, but whenever i tried to tighten the bowl onto the filter, it would slip.  i didn't see anything stripped and tried 2 different wix filters with the same result.  i think they were just offsize from the original detroit filter since they really wouldn't tighten up completely.  Now i don't care since we took the bowl/filter out. Smiley
Tom and Fran
8V92T, 740, satellite Internet, Fulltime working on the road.
« Reply #16 on: March 06, 2010, 05:19:27 AM »
Tom,
   Where are ya'll at now? Jim & Connie's?   We are planning to arrive at Jim & Connies tomorrow.  Tell Sis we said Hi.  Jack
