April 27, 2018, 12:08:00 AM *
Author Topic: After Market Cruise Control  (Read 7336 times)
chuckd
« on: March 07, 2010, 02:51:32 PM »
If you have  read my trip home report you know my cc does not work.  I am going to do a search of all my documentation to see if I can find out what type it is etc., but I don't hold out a lot of hope.
When I searched the forum it seems that King Cruise Controls and Rostra are mentioned the most.  It looks like Rostra is less expensive, so why not use the least cost alternative?  My Prevost has a high idle setting already, and Pete is a board member and fellow GMC (fwd) owner.
So what is the collective wisdom between the two in terms of performance and ease of install?
Thanks in advance as always.
Chuckd
1979 Prevost 35 footer
Stillwater Mn
pvcces
« Reply #1 on: March 07, 2010, 07:37:58 PM »
We have a Rostra and it has done well. In the beginning, shortly after the install, we had some settings to change and a simple wiring failure.
The wiring failure wasn't serious, but getting used to the multipurpose design caused some scratching of our heads.
The shutoff feature that responds to a brake light signal or wiring failure is supposed to work with either a normally open or normally closed brake light circuit. This means that there must be a path for a small sensing current to flow through at all times, or the cruise will drop out.
These older GMs used a turn signal switch that has a break before make design, so turning the turn signal on or off could cause the cruise to quit. It didn't happen all the time, which made the problem a little harder to solve.
The solution was to connect a lamp load to the brake light line so that there would always be a current path for the sensing circuit. I used a 12 volt trouble light for this purpose, and that ended the dropping out problem.
The cruise is a little slow to respond to a loss of speed, so that we lose a couple of MPH before it gets on the throttle when we go through a dip. Other than that, it does fine.
For what it's worth.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
« Reply #2 on: March 07, 2010, 07:49:45 PM »
The poor speed regulation "feature" would turn me off.  I know it would impact MPG a little.  Is the King any better at regulation?  If not then it is a moot point but if it does a better job then......just how much more expensive is it?
2 cents....or less,
« Reply #3 on: March 07, 2010, 08:06:24 PM »
If you have a King now just repair it they have great tech support and parts.
I have a 2500 King no complaints but there is a difference in price between the 2 yours on that model of Prevost should be a Dana or Bendix some models runs off a speedometer cable if it hasn't been replaced
« Last Edit: March 08, 2010, 05:19:08 AM by luvrbus » Logged
« Reply #4 on: March 07, 2010, 10:07:12 PM »
I have the King Cruise that simply pulls down on the gas pedal at the driver's seat, and it works very well. Since I have a Jake Brake, I don't have a high idle, which the King Cruise can be used as.  Will use the King Cruise again on my truck conversion (can you believe I drove the truck without cruise control for 12 years and 700,000 miles?)  Good Luck, TomC
viento1
« Reply #5 on: March 07, 2010, 10:32:18 PM »
I currently have the king2500 and it has recently failed, the cable seems to be jumping around like a gear is broken or something. It is on my list of fixes for spring. I Have to say that they couriered a shiny new manual directly to me and are very accountable - a pleasure to deal with for sure!
Ok, it's time to go on another road trip.
www.randalclark.com
MC5
chuckd
« Reply #6 on: March 08, 2010, 04:56:09 AM »
Okay, 3 Kings 1 Rostra.  Where is King Controls, it used to be part of the King Sat system.  Actually it was way before the King Sats, now I don't see it on the web site for the sats.  Where is the home page anyone?
Thanks again
Chuck
RickB
« Reply #7 on: March 08, 2010, 05:08:46 AM »
Chuck,
We had an inoperative Dana on our bus when we bought it I ended up pulling it out because I couldn't find parts for it.
You are in stillwater? We're in north st Paul. If you ever need any help let me know.
Six one two 385-7397.
We have a pretty healthy bus community in our area.
I would go with the cruise that has the best parts supply if I wanted to install it.
Rick
dbenck
« Reply #8 on: March 08, 2010, 06:47:03 AM »
Chuck,
Cruise King LLC - 22250 Glynview Trail   Faribault  MN  55021
Ph. 507-334-0250   Fax.  507-334-0206
E-mail:  mail@cruisecontrolking.com
David Benck
Somerset, WI
« Reply #9 on: March 08, 2010, 07:01:22 AM »
www.kingcontrols.com for satellite
www.cruisecontrolking.com for cruise control
www.trektets.com  for both
« Last Edit: March 08, 2010, 07:40:27 AM by luvrbus » Logged
« Reply #10 on: March 08, 2010, 07:33:01 AM »
Chuck,
Aren't you glad you bought your bus! Look at all the great help you get!
chuckd
« Reply #11 on: March 08, 2010, 07:40:04 AM »
Holy smokes ask and you shall receive!
Thanks a bunch.
David did you get my e-mail?
Chuck
Greg Roberts
« Reply #12 on: March 08, 2010, 08:12:28 AM »
I bought a Rostra from Pete and it is a very good cruise. The issue with MPH dropping a couple before it responds as mentioned earlier in this thread is really only a matter of adjusting the dip switches to get the response that you want and within the capability of your power to weight ratio. The support with Rostra is very good as well. I also use a wireless control on my Rostra and it works perfectly as well.
Check out my Eagle 20 here: http://photobucket.com/GregRobertsEagle20
« Reply #13 on: March 08, 2010, 08:33:45 AM »
A lot of difference installing a cruise on a DDEC and a MUI Greg I find the Rostra will not maintain on a MUI engine but I didn't buy the units from Pete and had Rostra and the guy in Houston trying to help and the guy in Houston knew nothing and the only thing Rostra would say was the that return spring was to stiff so now I have a King
Greg Roberts
« Reply #14 on: March 08, 2010, 09:12:48 AM »
That is a very good point. Yes, my unit is a DDEC with the electronic throttle and the unit is pulling the throttle perfectly. the MUI must take a lot more torque from the cruise unit.
