May 25, 2013, 04:49:28 PM *
Author Topic: windshield nightmare  (Read 1767 times)
ruthi
« on: March 20, 2010, 06:08:23 AM »
We are having the windshield in the Dina replaced. It is turning into a nightmare. We bought a new rubber gasket, and they tried to put in the windshield, and said they couldnt get it in, that it was too tight. This went on a long time. They said they could use the old one. We were getting pretty upset at this point, so we told them to just do it. Well, they broke one. So, now we have got to order a new one, driver side. Then, we had a new window made for the driver side window, they didnt use the rubber gasket on it, they glued it in!  Shocked  I know all windshields are different, but, I was wondering if the gasket is suppose to be installed first, and then put the windshield in, or put the windshield in the gasket and then install it all at one time. We are going to try to find someone else to install it when the new one arrives, but pretty leary now. Has anyone had this done near Macon, Ga? Dont know who to trust, and can actually do it right. Oh, another suggestion but the guy who tried to put it in, was that we grind the glass down a quarter of and inch or so, so that it isnt so tight?HuhHuhHuhHuh Never thought this would be one of the big issues............... Huh
southeast most of the time.
« Reply #1 on: March 20, 2010, 06:16:08 AM »
Ruthi,
   I can't speak about a Dina, I have never seen one, but on our MC-8, we installed the new rubber gasket in the bus first. We then installed the windshield in the gasket. We took our time, using plenty of dish soap as lubricant and a couple small pieces of oak (about like a thick popsicle stick) to work the rubber over the edge of the glass. Last step was to install the rubber locking strip into the gasket.  Jack
« Reply #2 on: March 20, 2010, 06:30:19 AM »
On our Eagle we installed the rubber first with a piece of 3/8" rope under the inside lip to aid in installation after the glass was in place. Pulled on the rope over and around the inner frame that is secured to the main frame. Worked the rubber seal with a tool made from UHMW for installing glass. Then installled the lock strip with another tool made for the job. I used a deluted spray bottle of soapy water to make it easier to work the rubber.
This was to install the original glass, not new. I did this all by myself with a cheap suction cup tool from Harbor Freight.
Sure hope it goes better for you the next time.
« Reply #3 on: March 20, 2010, 06:36:52 AM »
Ruthi, when you buy some after market windshields you have that problem and also with a roof raise the openings get a little off even without touching the opening and grinding the glass is the only option left.
Is the windshield from Curved Glass if so some of their Mexico made windshields just don't fit compare it to the old one.
And who knows for sure but the old ones could have been ground down it is not uncommon to grind a windshield
« Last Edit: March 20, 2010, 07:10:25 AM by luvrbus » Logged
muddog16
« Reply #4 on: March 20, 2010, 06:57:46 AM »
Ruthie, the tools Paul has in his photo.........are the tools to use.......those composite hand tools are awsome and you can find them at Harbor freight also and they are about 3 bucks.  The cord locking tool is also the tool to use.
I broke two windshields when I was installing my front windows, but it was my fault, when I raised the roof I closed the opening up in two directions for a total of maybe a 1/4".   After backing up and opening the windshield opening.....it went right in!  It's a two man job!   Soap and lots of water make it work, put the gasket in the opening, then start the center post section by pushing it into the groove while working the top and bottom gasket over the window take your time!
Pat
1982 Prevost LeMirage
8V92TA/HT754
« Reply #5 on: March 20, 2010, 07:40:53 AM »
Ruthi, I know most here on the board buy from Curved Glass but I found Coach Glass in Eugene Or a lot better to deal with and a far better product. http:// www.coachglass.com
« Last Edit: March 20, 2010, 07:44:30 AM by luvrbus » Logged
James77MCI8
« Reply #6 on: March 20, 2010, 09:14:29 AM »
Well this time when I visit you will have to turn the lights off in the bus to keep it cool. Hang in there Friday is a coming!
77 MCI 8
8V-71 4 spd
« Reply #7 on: March 20, 2010, 01:46:32 PM »
Clifford,
   We got a price from Curved Glass because everyone told us they were the cheapest (and they were). Until we added crating and shipping.  Overall, MCI was much cheaper with free packaging & shipping.  Jack
« Reply #8 on: March 20, 2010, 02:33:43 PM »
for the prevost guys 179 dollars each delivered to you.
« Reply #9 on: March 20, 2010, 02:34:50 PM »
sorry didn't say from prevost parts...bob
« Reply #10 on: March 20, 2010, 03:10:50 PM »
Now that's interesting.  Which prevost glass is it...or more exactly is the prevost windshield always the same part #.  I ask because I am pretty sure the glass I took from the 75 prevost is an exact match, if not it is within 1/4" grinding distance.  So this makes me think...as all the gmc highway coaches ('53-80?) are the same, we all have a good price on windshields.  Does this sound right to anyone?  BTW if you are sick of my posts it won't last long...I'm under-employed right now, wife's out of town and I'm full on bus for a bit.
p.s.  was talking to an old timer the other day, he's doing a MCI, he's old school quebecois, been in the bus business forever, his take on Prevost back in the day, was that he (Prevost) always just took bits and pieces and "borrowed" everyone else's idea and put together buses...the early ones are pretty much truck chassis with windows.  This was nothing new but they were doing it long after the others in the game were much more bus specific in chassis and design.
Anyhooo, seeing as apparently Prevost just mixed and matched it really does make sense that the glass would be the GM glass.
bryanhes
Eagle Model 10 "For Now"
« Reply #11 on: March 20, 2010, 04:27:34 PM »
I had  been told that the side windows on allot of the Prevost is the same as the windshield on GMC's.
Bryan
« Reply #12 on: March 20, 2010, 04:39:36 PM »
Yeah I heard that as well.  Unfortunately the donor bus is all tinted plexi glass, I'll check it out though, might fit.  Could be good vandal glass.
« Reply #13 on: March 20, 2010, 09:04:04 PM »
The gasket on Ruthi's Dina is all one piece.  There is no lock strip.  The lack of the lock strip is why the windshield replacement is so difficult.  It doesn't help that the rubber gasket is much thicker than most.
I believe they got the windshields from MCI as nobody else sells them for a Dina so far as I know.  The way the roof was raised should absolutely not affect the windshield fit.
« Reply #14 on: March 21, 2010, 05:39:58 AM »
Belfert, www.coachglass.com they list the Dina windshields in their inventory fwiw
