June 21, 2018, 10:40:46 PM *
Author Topic: Engine stopped, on the side of the road  (Read 8428 times)
5B Steve
« on: March 27, 2010, 12:05:50 PM »
     Hey Guys,
   I'm with a friend, engine has no power, had a service truck come and help but they don't know whats wrong.
   Plenty of fuel, changed fuel filters,now the engine will turn over but won't fire even on either. fuel through the lines.
   tank full.  does anyone have any clue what,s going on .   switch off, wire loose?  I'm posting this on my I-phone hopefully
  someone will have a idea.   MY CELL  IS  317-358 7520
   Thanks!
   Steve 5B........
5B Steve
« Reply #1 on: March 27, 2010, 12:07:42 PM »
    Guys that engine is in a MCI  8V-71
  Steve 5B........
Don Fairchild
« Reply #2 on: March 27, 2010, 12:17:01 PM »
Sorry the hear of the troubles but,
If the engine turns over and no smoke, you know it is getting fuel. I would suspect the blower drive. Pull the air horn and see if the blower is turning.
Hope this helps
Don
Sam 4106
« Reply #3 on: March 27, 2010, 12:18:25 PM »
Hi 5b Steve,
It sounds like the engine is starving for air. This is only a guess but maybe the air damper in the blower inlet got triped. The air damper is held open by a latch that can be triped by either the solonoid or by hand. The other possibility is the shaft that drives the blower broke.
Good luck, Sam MC8
fe2_o3
« Reply #4 on: March 27, 2010, 12:47:46 PM »
Fuel pump?...Cable
Sofar Sogood
1953-4104
KB7LJR
Everett, WA.
« Reply #5 on: March 27, 2010, 12:54:33 PM »
Electric controlled or mui?
fortyniner
« Reply #6 on: March 27, 2010, 12:55:45 PM »
When it cranks does it sound like it still has good compression? Did it get hot before it lost power?
Tom Phillips
PD4106-453
PD4106-2864
87 Alfa Milano
93 Range Rover
87 190e-16 Mercedes
92 Jeep Comanche
fortyniner
« Reply #7 on: March 27, 2010, 12:56:29 PM »
Post your location.
Tom Phillips
PD4106-453
PD4106-2864
87 Alfa Milano
93 Range Rover
87 190e-16 Mercedes
92 Jeep Comanche
fe2_o3
« Reply #8 on: March 27, 2010, 12:58:40 PM »
Schraeder valve?...Cable
Sofar Sogood
1953-4104
KB7LJR
Everett, WA.
5B Steve
« Reply #9 on: March 27, 2010, 01:21:59 PM »
Hey guys.    What is a schrader value. No it wasn't hot befor it shut down.    Steve 5B....
fe2_o3
« Reply #10 on: March 27, 2010, 01:29:22 PM »
Sits on the engine. Piston pushes crescent shaped arm that shuts off the fuel. If it doesn't relax you get no fuel. Last time it happened to me. I unbolted it from the manifold so the crescent arm could open and we could move...Cable
Sofar Sogood
1953-4104
KB7LJR
Everett, WA.
fe2_o3
« Reply #11 on: March 27, 2010, 02:00:47 PM »
Did he hit the Emergency Stop switch? Closes flapper at blower..Cable
Sofar Sogood
1953-4104
KB7LJR
Everett, WA.
« Reply #12 on: March 27, 2010, 02:45:59 PM »
Here is the engine stop cylinder on top of the governor. If the piston is sticking out, it will keep the fuel shout off.  If you loose power to the solenoid that controls this piston or the solenoid fails, this piston will not retract. The piston can be moved by removing one of the 2 mounting screws and twisting the piston to the side so the piston no longer contacts the engine stop lever.  Jack
« Last Edit: March 27, 2010, 02:56:37 PM by JackConrad » Logged
« Reply #13 on: March 27, 2010, 03:35:54 PM »
Just spoke with him ..they are running...Alge in tank
« Reply #14 on: March 27, 2010, 05:39:30 PM »
Interesting conclusion, but I thought he had said it would not start even with ether.  I would think that if there was ether, air and compression it would turn over.
