May 24, 2018, 08:37:05 PM *
Author Topic: Fuel return line  (Read 983 times)
wal1809
« on: March 31, 2010, 09:14:12 PM »
I have been studying the fuel lines on my eagle.  It has a 6v92. I have figured out all but the fuel return line.  I have been told a dozen times it is located at the rear of he motor.  Well my big butt can't find it.  What I did find is an unexplained fuel line that goes right along side with the fuel inlet hose.  I think it is it.    Is it possible it could be that easy, just sitting right there with the other hoses.
www.snakebreaker.com
« Reply #1 on: March 31, 2010, 09:21:08 PM »
NOT A CHANCE!
« Reply #2 on: April 01, 2010, 05:58:08 AM »
Wayne, looking from the front of your engine, from the fuel pump 1 line goes to the left head, another line goes from the left head to the right head if there is not another line leaving the right head the return line will be on the back of that head simple huh.
I know nothing about the wvo setup but you may consider a DDEC fuel pump one that has outlets for each head and supplies fuel not using the cross over method just a thought plus they are better pumps with more volume and you can use a larger orifice on the return I use one on my 8v92
« Last Edit: April 01, 2010, 06:20:16 AM by luvrbus » Logged
